How to access the heater core barbs on a Fusey? #1916325
09/20/15 09:22 PM
09/20/15 09:22 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I replaced the heater core in the Imperial and wanted to get the hoses on the car before I put the engine back in.
I've been searching and groping the firewall for an hour and can't find the stinking things.
Do I need to pull the fender liner to get to them?
- Stu Harmon
Re: How to access the heater core barbs on a Fusey? [Re: feets] #1916346
09/20/15 10:02 PM
09/20/15 10:02 PM
USA
Grizzly69 Online content
Grizzly69  Online Content
USA
They're actually under the firewall if I remember correctly.
When I replaced the heater hoses on my '72 Imperial, I had to do it from under the car.
Even then, they were tough to get to.
I'd definitely do it before you put the engine back in.
Re: How to access the heater core barbs on a Fusey? [Re: feets] #1916701
09/21/15 01:56 PM
09/21/15 01:56 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I couldn't find them from the top or the bottom. I found the evaporator drain but not the heater core.
I had to put the engine back in while I had inertia. The heater hoses were on the to-do list before the engine stab but I had to keep going while I was in the mood.
- Stu Harmon
Re: How to access the heater core barbs on a Fusey? [Re: feets] #1917176
09/22/15 01:08 AM
09/22/15 01:08 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, remove the inner fenderwell. That's how I had to do them on my old '69 Polara. It's not hard to remove.
Re: How to access the heater core barbs on a Fusey? [Re: Jim_Lusk] #1917480
09/22/15 03:33 PM
09/22/15 03:33 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It's a two piece arrangement so I thought I'd pull the outer and see if that will do the trick.
Thanks.
- Stu Harmon
