How to access the heater core barbs on a Fusey?
#1916325
09/20/15 09:22 PM
09/20/15 09:22 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I replaced the heater core in the Imperial and wanted to get the hoses on the car before I put the engine back in. I've been searching and groping the firewall for an hour and can't find the stinking things.
Do I need to pull the fender liner to get to them?
Re: How to access the heater core barbs on a Fusey?
[Re: feets]
#1916701
09/21/15 01:56 PM
09/21/15 01:56 PM
feets
Senior Management
Senior Management
Irving, TX
I couldn't find them from the top or the bottom. I found the evaporator drain but not the heater core.
I had to put the engine back in while I had inertia. The heater hoses were on the to-do list before the engine stab but I had to keep going while I was in the mood.
[Re: Jim_Lusk]
#1917480
09/22/15 03:33 PM
09/22/15 03:33 PM
feets
Senior Management
Senior Management
Irving, TX
It's a two piece arrangement so I thought I'd pull the outer and see if that will do the trick.
Thanks.
