Lower control arms difference
#191615
01/12/09 06:22 PM
01/12/09 06:22 PM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
Well I got some answer in the first round that lower control arms in E-bodies have the sway-bar end-bracket in the middle of the arm. OK. But most of the Barracudas did not have swaybars at all so how do I know the difference between A, B and E body control arms?????
Thordur Ingvarsson, Reykjavik Iceland
1970 Dodge Challenger R/T 440 sixpack Shaker(sold)
1971 Plymouth Cuda pro-street project
2007 YAMAHA YZF R1 189 HP
2007 YAMAHA FZ1 SA 150 HP
2003 Mercedes Benz E-200 Kompressor 163 HP
toti62@internet.is
Re: Lower control arms difference
[Re: 70rtshaker]
#191616
01/12/09 06:25 PM
01/12/09 06:25 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
They are stamped on the arm (I found this out after asking some ID help a while back..) a small couple of letter code on the arm itself will let you know what it's from
From memory it was near the end where the lower ball joint attaches, stamped into the side of the arm itself.
[Re: OzHemi]
#191617
01/12/09 06:56 PM
01/12/09 06:56 PM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
one is stamped near the ball joint end
PD RR
and 227 just below the adjusting bolt halfcircle hole
The other one is
VL LR
and that means???
toti62@internet.is
[Re: 70rtshaker]
#191620
01/12/09 09:25 PM
01/12/09 09:25 PM
RapidRobert
The E body LCA's are much shorter than the A body ones. I used one on my circle track A body on the dr side to get a ton of positive camber. When I go around the (left) turns the car leans to the right & this gets my camber back(close to)zero
