440 jerking/surge while cruising and light acceleration
#1915863
09/19/15 09:30 PM
09/19/15 09:30 PM
Posts: 318 Fort Collins, Colorado
CoDart
I have a 440 that has a jerking motion while light cruising and when accelerating lightly/medium. I do have a wideband hooked up and i can see it fluctuate between 13.5-14.3 af. The car idles great at 13.8 af and has no stumbles any where. I just need to figure out what the bucking is all about. Could it be light distributor springs?
The specs on the build is: 440, 10.5 compression, 91 octane, ported iron heads, lunati voodoo solid roller(249/252 duration), 4500 stall, 3.23 gears, 950 double pumper.
As the Holley only has a full vacuum hook up, the factory distributor is hooked to that. The car is a full street car and hasnt seen the track yet as I have just got it fired up.
Thanks for the help!
Re: 440 jerking/surge while cruising and light acceleration
[Re: CoDart]
#1915900
09/19/15 11:02 PM
09/19/15 11:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I doubt it's too much timing, per se. What's likely happening is that as he opens the throttle the vacuum drops off and his timing retards. As the manifold vacuum bounces around, so does his timing. Simple test, pull and cap the vacuum line to the distributor and see if it goes away.
[Re: CoDart]
#1915925
09/19/15 11:51 PM
09/19/15 11:51 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
[Re: CoDart]
#1915959
09/20/15 02:07 AM
09/20/15 02:07 AM
RapidRobert
Hello Ori. you might block the rods up (eddy) or go 4 sizes richer on pri jets (holley) for a quick test & see if that is it. As said cap the can & see what that does. check rotor phasing. then if no luck I would get scientific & note the RPM that it does it at then back at home see what your total timing is at those (RPM) points and tape a vac gauge to your windshield & see what range of in hg it is in when it acts up. keep us posted!
[Re: CoDart]
#1917180
09/22/15 01:17 AM
09/22/15 01:17 AM
RapidRobert
I ain't a Holley guy but I would want to get the pri system dialed in first. If I'm reading that right that at 30 MPH the cruise is 12.5 & I'm thinking that is what you'd want at WOT. I'd play with the pri jets but that might be too simple an idea. See what the guys say
[Re: minivan]
#1917592
09/22/15 07:25 PM
09/22/15 07:25 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Make sure your timing is spot on also... Exactly , lose the vacuum advance till you get everything squared away and them figure it out from there. What altitude are you at and does your gas have Ethanol in it ?
[Re: CoDart]
#1920364
09/27/15 12:31 AM
09/27/15 12:31 AM
RapidRobert
After some more cruising I found that if I plug off the manifold vac advanced on the distributor the car does not surge when accelerating or cruising. Ori your sayin that the can is now capped? The can alters rotor phasing, it increases the reluctor gap, it adds timing. checkout the first two and note the RPM range you are cruising and accelerating in (that you mentioned) without the can (if I read that right) then plug in the can to manifold and back off the initial (turn the housing) till the timing total at your RPM range is the same as what it was earlier with the can capped (& no surging) (duplicate the amt in your driveway) & go out & see if the surging is still gone
[Re: CoDart]
#1920701
09/27/15 04:34 PM
09/27/15 04:34 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
After some more cruising I found that if I plug off the manifold vac advanced on the distributor the car does not surge when accelerating or cruising. I think I need to hook the advanced up as PORTED but I do not have a ported port on my Holley. What do I need to make it ported?
Thanks! Glad that this was it. Easy to check and correct. It is not uncommon for an engine to buck under these conditions due to too much timing.
[Re: CoDart]
#1920781
09/27/15 07:07 PM
09/27/15 07:07 PM
Supercuda
About to go away
About to go away
up yours
None of you seem to realize that the only difference between ported and manifold vacuum occurs at or very near closed throttle. I suggest you read up on how to adjust when the vacuum advance kicks in. http://www.dodgecharger.com/forum/index.php?topic=14888.0
[Re: BSB67]
#1920864
09/27/15 10:09 PM
09/27/15 10:09 PM
RapidRobert
Supercuda, it would appear to me (from the content of our posts) that both me and BSB67 are thinking that the can is adding too much adv not that it is a porting/manifold selection issue. & I'd like to see Ori check the reluctor gap and rotor phasing
[Re: CoDart]
#1920905
09/27/15 11:25 PM
09/27/15 11:25 PM
Supercuda
About to go away
About to go away
up yours
I was trying to enlighten the OP. You can adjust at what vacuum level the advance kicks in, he may very well be right on the tipping point at cruise and it's cycling on him.
