Re: 69 Charger header panel studs
[Re: fastmark]
#1917257
09/22/15 09:33 AM
09/22/15 09:33 AM
resq302
resq302
Check with AMK and see if they sell them? downfall is that you need to have a $30 min order with them.
[Re: fastmark]
#1924112
10/02/15 01:33 PM
10/02/15 01:33 PM
Posts: 21,485 It's a dry heat
gtx6970
It's a dry heat
Thanks guys. Those are close but not quite right. I was hoping someone was making these. Nope, I've done a few 68-69 Charger grilles and had to repair several of the broken studs. I grind the broken stud off flush with the base , drill it out all the way thru, tap the hole 1/4-20 . Then thread a stud 1.25" long into and tack weld it from the backside. Once welded in grind the back side flush. Then prep and paint it, once done you can not tell it was ever done
[Re: fastmark]
#1924301
10/02/15 05:38 PM
10/02/15 05:38 PM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
Well in my case I don't have the head to weld it too. The entire leg of the brace was either twisted off or it was cut off to repair another grill. I'll post a picture of my repair when I'm done.
[Re: fastmark]
#1924464
10/02/15 09:32 PM
10/02/15 09:32 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
KInda looks like the studs on the E-brake assembly, might have luck scavenging some of those.
Careful, your character's showing!
[Re: mopar346]
#1926088
10/05/15 10:25 AM
10/05/15 10:25 AM
gtx6970
It's a dry heat
KInda looks like the studs on the E-brake assembly, might have luck scavenging some of those. Park brake assy mounting studs are 5/16" threads . Charger gille studs are 1/4-20 To the op. I had a grille with a missing lug on the mounting leg. Fortunately, I had a parts grille I could rob pieces from to repair the one I redid,,,, Short of doing the same. I think your in for some serious fab work
[Re: gtx6970]
#1926346
10/05/15 04:37 PM
10/05/15 04:37 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Thanks guys. Those are close but not quite right. I was hoping someone was making these. Nope, I've done a few 68-69 Charger grilles and had to repair several of the broken studs. I grind the broken stud off flush with the base , drill it out all the way thru, tap the hole 1/4-20 . Then thread a stud 1.25" long into and tack weld it from the backside. Once welded in grind the back side flush. Then prep and paint it, once done you can not tell it was ever done GTX6970 has the right idea IMO
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
