727 Gasket ??? #1915790
09/19/15 06:40 PM
09/19/15 06:40 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Is there any place besides the dealer to get the hard tran. pan gaskets? I can go get one but it's about an 80 mile round trip to get it. If there is some where else I'll order me one. Thanks
Re: 727 Gasket ??? [Re: okie] #1915798
09/19/15 07:03 PM
09/19/15 07:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hard trans pan gasket?
Not sure what that is. I can think of three types, cork, rubber and steel cored silicon. Summit has all three typ3es
http://www.summitracing.com/search/department/gaskets-seals/section/transmission-gaskets-seals/part-type/transmission-pan-gaskets/transmission-type/torqueflite-727?N=4294949549%2B4294945238%2B4294923830%2B4294945319&SortBy=Default&SortOrder=Ascending
Don't be the exception.
Re: 727 Gasket ??? [Re: okie] #1915801
09/19/15 07:10 PM
09/19/15 07:10 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
It is a I think a neopreme hard core gasket
Re: 727 Gasket ??? [Re: okie] #1915964
09/20/15 02:23 AM
09/20/15 02:23 AM
the dealer reinforced pan gasket gets good reviews but in your case I'd try a cheap locally avail gasket & some goop & make sure the pan is flat expecially around the bolt holes (hammer as needed). EDIT I'd get some gasket material some cement some HF hole punches straighten the pan & make one your self, you'll be proud of your work & the distance for a tailor made one will be a non issue
Re: 727 Gasket ??? [Re: okie] #1916019
09/20/15 10:35 AM
09/20/15 10:35 AM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
1970 Duster 340 clone
Re: 727 Gasket ??? [Re: okie] #1916049
09/20/15 12:19 PM
09/20/15 12:19 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I believe A&A Trans sells the dealer style reusable pan gaskets.
Matt
Re: 727 Gasket ??? [Re: okie] #1916132
09/20/15 03:17 PM
09/20/15 03:17 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I have a new pan to put on it and I want to get it fixed this time
