67 Coronet.. Everything new or rebuilt...
Temp gauge was running a little warmer than usual the other night.. Checked water level, fan belt tightness/possible breakage, everything OK..
Happened again and I notice ALL of my gauges ( Voltage, fuel, and temp are all swinging to the right a couple of needle widths more.. As I drive along next look at the gauges, all are acting normal.
As said above, rebuilt gauges by redline, all new wire harnesses, electronic voltage regulator....
Any thoughts on here?? TY
