Cometic head gaskets, first time user??????? #1915637
09/19/15 01:54 PM
09/19/15 01:54 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Finished the short block on my 572 Keith Black engine last night and both the block and my B1 heads are smooth finished for Cometic gaskets. New gaskets, prepped finish, now should they go on dry with a silicon sealer around the water ports or do you guys spray them down with copper coat or something similar. Studs are being used. Thanks for any input.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915663
09/19/15 02:21 PM
09/19/15 02:21 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I drilled out the brass grommets & gave all the surfaces a coat of copper-coat. I have no leaks. They come off with a little fineness without any damage.
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915725
09/19/15 04:20 PM
09/19/15 04:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Same thing here. Zero leaks.
Re: Cometic head gaskets, first time user??????? [Re: HotRodDave] #1915745
09/19/15 04:49 PM
09/19/15 04:49 PM
PA.
"Little"John
"Little"John
PA.
Thanks guys. No silicon around the water ports?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915747
09/19/15 04:49 PM
09/19/15 04:49 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Had both block and B1 heads to à machine shop with à sunnen top deck. Stones to very smooth surface. Went on dry, no sealer and no problems.
Remove the rivets that where on the short sides, as they would have been jammed.
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915752
09/19/15 05:03 PM
09/19/15 05:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine are dry.
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915759
09/19/15 05:26 PM
09/19/15 05:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I never put anything else on them and never had a problem. The theory is to use them dry but I can't quite bring myself to trying it after hearing others with issues.
A little off topic here but I am getting ready to try some copper gaskets on a very high compression pump gas engine to wick away heat faster, not sure what I will use on that.
Re: Cometic head gaskets, first time user??????? [Re: HotRodDave] #1915767
09/19/15 05:41 PM
09/19/15 05:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lots of luck with that... try the copper spray to seal
wave
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915828
09/19/15 08:17 PM
09/19/15 08:17 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I put mine on dry the first time.... When I reused them I drilled out the rivets and sprayed them with copper spray sealer. No issues either time!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Cometic head gaskets, first time user??????? [Re: RT540] #1915839
09/19/15 08:28 PM
09/19/15 08:28 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Same here - dry and no issues.
Re: Cometic head gaskets, first time user??????? [Re: max_maniac] #1915851
09/19/15 08:37 PM
09/19/15 08:37 PM
PA.
"Little"John
"Little"John
PA.
I'm leaning towards dry especially since I am only putting this together right now so I can get the new car out for some passes this year NA before Winter. The engine will be out again over the Winter to make it more nitrous Friendly.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915862
09/19/15 09:23 PM
09/19/15 09:23 PM
AndyF Offline
AndyF  Offline
I always use them dry. That is what Cometic recommends and usually it makes sense to follow the mfg instructions.
Re: Cometic head gaskets, first time user??????? [Re: AndyF] #1915890
09/19/15 10:36 PM
09/19/15 10:36 PM
crabman173
crabman173
I agree--crazy not to listen to the guys that made them and I say again..
Coppercoat is NOT a sealer--it is a messy old product from the way back days when all they used were steel shim gaskets--usually only diesel mechanics used the stuff--it is not what you want--I guess you guys still have Indian Head Gasket Shelac too???
When we re-use Cometics we spray with Hylomar spray in the can
Costs stupid high like $60 a can range but will allow re-use of Cometics SEVERAL times --Hylomar will seal it Period!
The only reason Cometics leak water is incorrect surface RA finish--ya can't deck a block with an old Storm Vulcan machine and use MLS gaskets--if RA finish is per spec and they are installed dry like noted they will seal up.
I am actually a big fan of adding a stop leak to any new build--It is a cheap and effective way to happiness.
We start new engines everyday--and even with perfect finish, thick gaskets etc sometimes a little water will dribble out between head and block--I run the hell out of them and by the time they come to temp usually it stops like magic--with stop leak in it always does --
Every horror tale about MLS leaking water is poor finish or clamping the rivets between something
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915893
09/19/15 10:39 PM
09/19/15 10:39 PM
crabman173
crabman173
That 572 is going to make you one HAPPY racer!! It may cause rear end, heim joint, trans, converter failures etc--heck it might even bend the roll cage smile
Re: Cometic head gaskets, first time user??????? [Re: ] #1915902
09/19/15 11:02 PM
09/19/15 11:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I used the Hylomar on copper gaskets(15-1 comp) with o-rings, what was recommended.
Re: Cometic head gaskets, first time user??????? [Re: ] #1915903
09/19/15 11:04 PM
09/19/15 11:04 PM
PA.
"Little"John
"Little"John
PA.
LOL. No this car is from North Carolina and those guys can build cars down there.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915911
09/19/15 11:24 PM
09/19/15 11:24 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I put them on dry......just as Cometic says. When I reuse them, I just put them back on, still with no sealer. Have reused a set as many as 6 times on a 632 nitrous motor that saw 3 kits of nitrous every pass it ever ran. Never leaked
Re: Cometic head gaskets, first time user??????? [Re: Monte_Smith] #1915918
09/19/15 11:36 PM
09/19/15 11:36 PM
PA.
"Little"John
"Little"John
PA.
Thanks guys I appreciate the help.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cometic head gaskets, first time user??????? [Re: HotRodDave] #1915935
09/20/15 12:17 AM
09/20/15 12:17 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I use flatout copper head gaskets.
Re: Cometic head gaskets, first time user??????? [Re: pittsburghracer] #1915990
09/20/15 04:38 AM
09/20/15 04:38 AM
I normally put them on per Cometic instructions, dry thumbs I have used Copper coat on a used set that was shedding the viton(or what ever the rubber looking coating actually is confused) coating per a customers demands, no difference or sealing up problems on his motor though confused shruggy Maybe there is more than one way to seal these rascals up work
