brake valve #1915410
09/19/15 12:39 AM
09/19/15 12:39 AM
Shippensburg, PA
GardnersGotCudas Offline OP
Shippensburg, PA
where can I get 72 charger proporition valve rebuild at? thanks
Re: brake valve [Re: GardnersGotCudas] #1915461
09/19/15 02:34 AM
09/19/15 02:34 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
See:
https://www.musclecarresearch.com/1970-71-mopar-brake-tube-tee-autopsy
He sells repair kits and shows how to install them yourself.
Be sure to use heat on the brass hex head fitting, or you'll deform the hex head and ruin it. DAMHIK.
Re: brake valve [Re: GardnersGotCudas] #1917081
09/21/15 10:48 PM
09/21/15 10:48 PM
Shippensburg, PA
Shippensburg, PA
is there any body else?
Re: brake valve [Re: GardnersGotCudas] #1917255
09/22/15 09:32 AM
09/22/15 09:32 AM
resq302
resq302
White post restorations does a very nice job. A little more expensive but offers a lifetime warranty.
