Re: removing wheel when lugs are spun
[Re: Mr.Yuck]
#1914961
09/18/15 12:13 PM
09/18/15 12:13 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I assume the drum is on the spindle and you can take the spindle nut off and pull the wheel with the drum and get at the backside ?
[Re: Mr.Yuck]
#1914992
09/18/15 12:45 PM
09/18/15 12:45 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
51 with lug nuts?Every old Mopar Ive had or seen before 56 I believe had bolts not lug nuts.Even the early straight axle I had under my 65 had lug bolts.Rocky
Chrysler Firepower
[Re: therocks]
#1914997
09/18/15 12:48 PM
09/18/15 12:48 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
51 with lug nuts?Every old Mopar Ive had or seen before 56 I believe had bolts not lug nuts.Even the early straight axle I had under my 65 had lug bolts.Rocky Rocks, the rear had bolts and was the normal bolt pattern. The fronts are lug style and a wider bolt pattern...They have been swapped because somebody put the left hand studs on the passenger side.
[Re: Mr.Yuck]
#1915019
09/18/15 01:12 PM
09/18/15 01:12 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Split the nuts in two places with a death wheel and hammer in a wedge to pop the bit off.
Another solution is to grab the nut with vise grips angled so they can't spin around and drill the bolt out until you can break it off.
[Re: Mr.Yuck]
#1915028
09/18/15 01:25 PM
09/18/15 01:25 PM
RapidRobert
I do have a cut off wheel... Why does everything take twice as long as it should? I'd suggest useing the cutoff rather than wallowing things out more with an impact & maybe making more damage. Murphys law it comes and goes (fortunately)
[Re: Mr.Yuck]
#1915195
09/18/15 06:24 PM
09/18/15 06:24 PM
Posts: 5,919 ohio
ruderunner
ohio
If you ghot a welder, pull wheel and drum. Tack the studs in an remove lugs.
Angry white pureblood male
[Re: BSB67]
#1915386
09/18/15 11:56 PM
09/18/15 11:56 PM
Mr.Yuck
Brookeville, Md
Trying to save the lugs? If not, just break them off. Take about 30 second per wheel. they just spin... well spun. I took my grinder zipped them right down the middle and popped the nuts off. 2 wheels 2 beers and 15 minutes and it was done. I'll pull them off tomorrow and knock the lugs out.
[Re: Mr.Yuck]
#1915737
09/19/15 04:37 PM
09/19/15 04:37 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Trying to save the lugs? If not, just break them off. Take about 30 second per wheel. they just spin... well spun. I took my grinder zipped them right down the middle and popped the nuts off. 2 wheels 2 beers and 15 minutes and it was done. I'll pull them off tomorrow and knock the lugs out. Right. Put a socket on it with a long extension on it. Stand on the extension.
[Re: Mr.Yuck]
#1915837
09/19/15 08:26 PM
09/19/15 08:26 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have to admit I have never spun a stud in a hub before. I've snapped them off, rounded off the nuts. Buy some new studs and tack them in.
