Basic Steel rims. hard to find
#191485
01/12/09 03:48 PM
01/12/09 03:48 PM
Posts: 230 Long Island, New York
Tony H
E-baying and asking around locally and cannot seem to find basic steelies for my kids '74 Dart
14" 4.5" x 5 hole pattern I think they are 6" with a 3.5" offset. Can someone confirm what will fit without rubbing?
What other cars can I look for to get equivalent rims? Ford, AMC?
'75 CJ5 with all glass body and a 350 Chevy SB '85 Chevy Stepside (the wife's) '89 Volvo All 100% maintained by me. '70 valiant DD for my son '74 Dart Swinger..Latest endeavor http://home.lyse.net/brox/TonyPage4.html
Re: Basic Steel rims. hard to find
[Re: Tony H]
#191487
01/12/09 04:11 PM
01/12/09 04:11 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
If you have the large bolt pattern, a 15" wheel that will fit well on that car is only a Dodge Diplomat away.
Oh yeah, and a lot of 87-91 4cyl dakotas came with 14" wheels that I believe will work on the large bolt A-bodies without issue.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Cuda340]
#191490
01/12/09 05:23 PM
01/12/09 05:23 PM
Tony H
I was just calculating.. I could go with 15's
I have 205 70 14 tires on it now. I guess 205/65/15 would come close to the same diameter.
I got the Offset from a rim that was in the trunk, I assumed it was stock. The car has Cragar SS's on it. they are in sad shape, one leaks badly even after trying to sand the Bead area clean.. not to mention I wanted the steelies for Snows.
Thanks for the options, It will make the search easier.
[Re: 68 Coronet]
#191492
01/13/09 09:56 AM
01/13/09 09:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
stock mopar rims are approx. 1/4" positive offset, so if you have a 7" rim (8" overall width) it should have 4.25" bs.
a 5" rim (6" overall width) will have a 3.25" BS. a 5.5" rim (6.5" overall width) will have 3.5" BS, etc, etc.
if you want 15's, a dippy or 5th ave is your best bet if you have the large bolt pattern. if you have drum brakes in front it will be a 5x4--the small bolt pattern. most ford rims will work on the large bolt pattern if you open up the center register .060 or so. small bolt pattern, newer 5x100mm can be made to work, at least for rolling the chassis around the yard.
[Re: Devil]
#191494
01/13/09 01:05 PM
01/13/09 01:05 PM
Posts: 1,044 minnesota
president61
minnesota
Why not upgrade to some 15" rims? 15x7 steelies were found on almost every mopar post 74. I pull them off of 5th Ave's and Dippys whenever I get the chance. Usually $5 to 10 each.
Ryan
15 inch steelies are very hard to come by here because they've all been destroyed on demo cars
