Hollow Popping Noise Left Front When Turning Wheels #1913571
09/16/15 11:23 AM
09/16/15 11:23 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
I have a popping noise that is coming from the front left of my 70 Challenger when I turn the front wheels. Once the car warms up and moves around a bit I don't hear it, but hear it when it's cool and I'm trying to navigate in or out of a garage space. What might it be?
1970 EK2 T/A 727
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1913606
09/16/15 12:18 PM
09/16/15 12:18 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
It sounds like a dry ball joint to me. I'd get it off the ground and visually inspect the front suspension first.
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1913704
09/16/15 02:36 PM
09/16/15 02:36 PM
AndyF Offline
AndyF  Offline
Could also be the tire. I had a tire once with a broken belt in it which would make a loud popping sound when the tire was cold. Once it was warmed up the tire didn't make any noise.
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1913947
09/16/15 07:19 PM
09/16/15 07:19 PM
first thing in the AM have someone turn the wheel with you on the ground underneath
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: AndyF] #1913994
09/16/15 08:19 PM
09/16/15 08:19 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
It has Goodyear Polyglas I don't think they have belts.
1970 EK2 T/A 727
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914003
09/16/15 08:43 PM
09/16/15 08:43 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I am also leaning towards a tire issue. Take 5 mins and rotate the tires to see if it goes away. Cheapest easiest check
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: moparjim79] #1914020
09/16/15 09:26 PM
09/16/15 09:26 PM
dogdays Offline
dogdays  Offline
Of course Polyglas tires have belts, fiberglass belts. They were the intermediate step between bias tires and radials. There was a whole class of bias-belted tires. The Polyglas were Goodyear's high performance model.
I am leaning towards something like a drag link that needs replacing.
R.
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914291
09/17/15 09:51 AM
09/17/15 09:51 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
I meant steel belts. I don't think it's a tire issue. It's a T/A so it has different size tires front and rear. Would look awfully funny if rotate the tires and put the larger tire on the front and the smaller ones on the rear. laugh
1970 EK2 T/A 727
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914332
09/17/15 11:08 AM
09/17/15 11:08 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You can still swap sides and see if the noise follows. But I am sure you already thought of that.
Craig
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914662
09/17/15 08:32 PM
09/17/15 08:32 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Just putting this out there, but when being driven at all, the tire is generating heat, creating a condition that would be more conforming and flexible at any given speed within reason, in my thoughts, therefore, causing the on again off again condition that you are describing. I don't see a ball joint doing that, or a drag link, but I personally would still look at all this stuff before driving the car at all. On a final note, didn't TA's originally come w the same tires on all four corners? Like the rest of chryslers built during that time?
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914668
09/17/15 08:44 PM
09/17/15 08:44 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Oh snap, e's up front and f's in da back. My bad.....but you could still swap around or out the tires
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914672
09/17/15 08:46 PM
09/17/15 08:46 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Ta's and hemi cars did have different tire sizes front to rear, my bad. You could still do a switcheroo though......
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1914927
09/18/15 11:27 AM
09/18/15 11:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How are the suspension parts ? I'm going thru this on a 2001 Ram right now , the bushings are loose in the control arms ... so far ....
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915224
09/18/15 07:14 PM
09/18/15 07:14 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Suspension parts all look brand new and well greased. However they were replaced about 10-15 years ago and the car has had maybe a couple thousand miles in that time. It really sounds like something is loose, but when it gets going and moving and heated up it seems like something may swell up and it doesn't make the noise any more.
I had a Ford Bronco a while back. They have issues radius arm bushing failure. When you would turn the wheel left or right while backing up and hit the brakes it would make about the same noise. Such as a bushing that is worn and not doing it's job anymore. Thing is on this one it's all new stuff, but it is older new rubber parts so it could have dried out from sitting, or something may not be tightened down enough. Don't know still diagnosing..............
1970 EK2 T/A 727
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915299
09/18/15 10:01 PM
09/18/15 10:01 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Had a chance to take the wheels off and take a look. Everything looks great, new and well greased except a rubber bushing that is under the control arm on the drivers side where the noise is coming from. See photos. I'm not sure what the part is called but it needs to be replaced as it is split. Maybe some kind of bump stop? If anyone can tell me what part I need to ask for that would be great.
1970 EK2 T/A 727
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915362
09/18/15 11:21 PM
09/18/15 11:21 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The part that is split is the upper control arm bump stop. with weight on the suspension it shouldn't be making contact with anything. The fact that its split has me thinking maybe the front suspension is not set at the proper ride height. Probably not you noise, but something that should be addressed.
Think I would put the floor jack under the lower control arm and move the body up and down to see what is making a small sudden jerk. As the suspension travels, everything should move smoothly and consistently. Whatever is not moving smoothly is probably your noise maker. It really could be anything in the suspension, anything attached to the suspension, or anything effected by the suspension. Old suspension rubber parts (that still may not have wear) tend to be a bit more still when they are cold, and soften up as the move. That stiffness can cause attaching points to move that are not suppose to move. Once the rubber parts soften a bit, and become more flexible, the parts that were moving may not move anymore.
I've seen poor penetration on factory spot welds on the upper control arm mounting braces that would allow the braces to twist with the control arm until the bushings softened up. Unibody cars make funny noises when the spot welds fail. Popping and snapping are tell tail signs, the the noise can travel through the car a long ways from the issue. Not saying this is your problem, but its is something I have encountered. Gene
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915443
09/19/15 02:02 AM
09/19/15 02:02 AM
UP
finn Offline
finn  Offline
UP
Check the wheel bearings.
Although of a different design completely, the "hollow popping sound while turning" fits to a "TEE" the noise my 4wd Ram made when the unit bearings were disintegrating.
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915542
09/19/15 10:31 AM
09/19/15 10:31 AM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Maybe a dry torsion bar socket?
11B40
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915572
09/19/15 11:51 AM
09/19/15 11:51 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
I've used a floor jack to raise and lower the control arms. I get the noise as the suspension raises up with each pump of the jack. Sounds like a ratcheting sound this way vs popping when it's done with the car weight on it, but it's got to be the issue. Problem is I can't pinpoint exactly where it's coming from but best I can tell it's coming from the bottom near where everything attaches to the subframe. Something that pivots and is supposed to rotate on its axis smoothly isn't. Not sure if there is anything I can lube there to help or not. I'll try to post a video of the noise.
1970 EK2 T/A 727
Re: Hollow Popping Noise Left Front When Turning Wheels [Re: f2502011] #1915575
09/19/15 12:00 PM
09/19/15 12:00 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Hopefully this will work. Please disregard the jack squeaking for some reason you can really hear it better on the video than in person, but you can also hear the popping noise that I'm trying to figure out and solve.
http://vid338.photobucket.com/albums/n439/kna4977/Mobile%20Uploads/IMG_0116_zps1ce41a87.mp4
1970 EK2 T/A 727
