Page 2 of 6 1 2 3 4 5 6
Re: Trick Flow Mopar head [Re: Trick Flow] #1913572
09/16/15 11:25 AM
09/16/15 11:25 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Any chance of building a small block head
Re: Trick Flow Mopar head [Re: Trick Flow] #1913577
09/16/15 11:30 AM
09/16/15 11:30 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
makes us wish we had ANY blocks!
Re: Trick Flow Mopar head [Re: 70RT Charger] #1913712
09/16/15 02:44 PM
09/16/15 02:44 PM
AndyF Offline
AndyF  Offline
Originally Posted By 70RT Charger
Since it didn't say nothing about Rocker Arms until the very last I assumed it they recommended rollers period. Andy the cam I was going to use was a 232-238 grind and 514/532 hydraulic I think. I was still wanting it to be very streetable and make long trips but would like the extra hp these heads bring also and run a dual plane intake also. I really wasn't wanting to buy the roller now but if I had to I would break down and buy them. What are sidewinders?
With a 514 hyd cam you could run stock rocker arms. You might double check the spring specs since you might need to swap in a softer spring to work with the stock rocker arms. So that combo will work, it just isn't what the heads are designed for.
Re: Trick Flow Mopar head [Re: scottb] #1913881
09/16/15 05:59 PM
09/16/15 05:59 PM
Tallmadge, Ohio
Trick Flow Offline OP
Tallmadge, Ohio
I'm not saying it isn't possible down the road, but currently there isn't anything on the drawing board.
Re: Trick Flow Mopar head [Re: AndyF] #1913905
09/16/15 06:31 PM
09/16/15 06:31 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Andy I might just go ahead and get the roller rockers. Will that cam still make a good combo with those heads and a dual plane intake or what do you suggest?...
Re: Trick Flow Mopar head [Re: Trick Flow] #1914758
09/17/15 11:41 PM
09/17/15 11:41 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Can't wait to get a set of these on the new shortblock!
Re: Trick Flow Mopar head [Re: Trick Flow] #1916125
09/20/15 02:51 PM
09/20/15 02:51 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Wahoo! Summit is now advertising these heads with a delivery date of 10/22. Looks like they may be for real.
Re: Trick Flow Mopar head [Re: Trick Flow] #1916710
09/21/15 02:09 PM
09/21/15 02:09 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Originally Posted By Trick Flow
Any standard rocker arm will work, but Harland Sharp makes a short and a long. Our head will require their short rocker arm.
How does somebody tell the difference between the "long" and "short" Harland Sharp rockers? I don't see anything on their web site that says this. confused
Re: Trick Flow Mopar head [Re: PorkyPig] #1917273
09/22/15 10:13 AM
09/22/15 10:13 AM
sweden
carter Offline
carter  Offline
sweden
X1.. I have mine HS rockers 1.5 since -91. Used them on 906 and Eddy RPMs do I have short or long arms confused
Re: Trick Flow Mopar head [Re: carter] #1917323
09/22/15 12:27 PM
09/22/15 12:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm not sure which are the ones you have but the heads you have , mainly the ebrocks , are the reason for the new ones.
I just looked at the sharp website and they don't list them , I THINK the Mancini branded rockers are the SHORT sharps.
Re: Trick Flow Mopar head [Re: JohnRR] #1917343
09/22/15 12:58 PM
09/22/15 12:58 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
I think what he is referring to is the 1.5 ratio and 1.6 ratio - Most heads will work out of the box with the 1.5 ratio - 1.6 usually requires some enlargement work on the push rod holes - (Long and short rockers is an old Chevy term)
The other rocker Sharp makes is the offset for the Indy style head or others like the victor head that requires an offset intake
Re: Trick Flow Mopar head [Re: DoubleD] #1917355
09/22/15 01:12 PM
09/22/15 01:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Free research for you prospective (or committed) Trick Flow head purchasers:
Trick Flow PowerPort 240 1.560 Spring
Valve Springs, Option 2: 1.560" o.d. dual spring with damper
240 lbs. @ 2.000" installed height
600 lbs. @ 1.280" open
500 lbs. per inch rate
.700" max. valve lift
TFS-16318-16 Spring
Inside Diameter of Outer Spring (in): 1.136"
Inside Diameter of Inner Spring (in): 0.750"
Trick Flow Ti Retainers (the only TF P/N I found that would match the TFS-16318 spring):
-------------------- OD ----1st Step - 2nd Step - Retainer
TFS-214T0525 --- 1.500 -- 1.110 -- 0.710 ---- 10* (+.050")
My experience w/ running Ti retainers on the street w/ springs having steel dampers hasn't been great, in that the dampers will definitely cut into the Ti retainer, yet a chro-moly steel retainer isn't fazed by this. So, I did some research on retainer options, specifically tool steel, for those who may want to swap out the Ti retainers for just that reason.
I don't know if the retainers w/ the 1.140" step OD for the outer spring will actually fit the TF-supplied spring since its ID is listed as 1.136". Not sure if those could be installed as a press-fit, or if that's simply too large to work w/o reducing the retainer step OD. IMO, the tighter fit, the better. However, it also looks like some of the other tool steel retainers I've listed should still have a better fit to the spring than the Ti retainers I believe Trick Flow is using w/ their supplied springs.
FWIW, if I was buying some TFs for my application (.650"-ish solid roller for street/strip), I'd probabaly get some Manley 23647TS tool-steel 10* retainers and expect that the installed height may need to be corrected w/ the change in retainer brand.
"You results may vary!"
Re: Trick Flow Mopar head [Re: DoubleD] #1917360
09/22/15 01:15 PM
09/22/15 01:15 PM
BradH Offline
BradH  Offline
Originally Posted By DoubleD
I think what he is referring to is the 1.5 ratio and 1.6 ratio...
I think what he's referring to is the pivot-to-roller-tip c/l distance of the standard BBM HS rocker being longer than ideal, which is the case for a number of aftermarket BBM heads.
IIRC, Todd from Competition Wedge (NY) worked w/ Harland Sharp to come up w/ a shorter version to address this, but don't know what the end result was as far as HS offering them for any particular heads.
Re: Trick Flow Mopar head [Re: BradH] #1917382
09/22/15 01:45 PM
09/22/15 01:45 PM
AndyF Offline
AndyF  Offline
Good info Brad on the retainers. When my TF heads get here I'll look into that. I've used the tool steel retainers on the last few engines so I might go that route again. Ti definately doesn't like the flat ribbon dampers.
Re: Trick Flow Mopar head [Re: BradH] #1917431
09/22/15 02:44 PM
09/22/15 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By BradH
[quote=DoubleD]
Todd did, he told me the rockers are out there now and he wasn't included.
Re: Trick Flow Mopar head [Re: BradH] #1920249
09/26/15 08:53 PM
09/26/15 08:53 PM
eastern,Ky
eastern,Ky
TFS-16318-16 Spring
Why would you sell a head with these retainers if that's the case
Re: Trick Flow Mopar head [Re: Trick Flow] #1923667
10/01/15 08:17 PM
10/01/15 08:17 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Anyone have a set yet?
Re: Trick Flow Mopar head [Re: Trick Flow] #1923721
10/01/15 09:20 PM
10/01/15 09:20 PM
Canada
Criterion Offline
Criterion  Offline
Canada
Yep. Fit and finish seem nice -- certainly better than the set of AFR SBF heads that I got last month. Very tidy OOTB and they have some nice features like a distributor clearance notch and from the looks of things some prounounced oil drain-back channels. As well, and unlike Edelbrock, Trick Flow seems to have tapped the holes for the rocker shaft studs/bolts nice and deep. Lots of thread engagement up
Here's an image album of them: Powerport 240 gallery
Re: Trick Flow Mopar head [Re: Trick Flow] #1923956
10/02/15 06:03 AM
10/02/15 06:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Summit lists them now. just under $1,000 with standard retainers and $1,099.50 with the Ti retainers.
http://www.summitracing.com/search/brand...par-big-block-b
Re: Trick Flow Mopar head [Re: 451Mopar] #1923969
10/02/15 08:50 AM
10/02/15 08:50 AM
eastern,Ky
eastern,Ky
What standard retainer do they run?
