Re: Removing under coating.
[Re: Dons Dart]
#1913580
09/16/15 11:37 AM
09/16/15 11:37 AM
Challenger 1
Cincinnati, Ohio
I am about ready to removing the under coating,I have used a putty knife to do a test the thing is the PO also used some kind of liquid rust check, the good news if there is such a thing the hard stuff is soft.OK so what can i use to get it off,this stuff is like oil,any tips will help greatly. I have used a hot water pressure washer and was able to get 100% off without damaging the metal or original paint/over spray. I used some gasoline in a pump up sprayer to soften up the hard stuff. In less than 4 hours I had the bottom of my car spotless, clean enough to eat off of. Rent one, you won't be sorry and you can move on to other more important things on your car. Pictures later.
[Re: Challenger 1]
#1914579
09/17/15 07:06 PM
09/17/15 07:06 PM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
In 1976 or so my first "real" job was working at a British car and motorcycle dealer and he raced a Ford Cortina. One of my first jobs was to remove the undercoating from the car with a putty knife and a propane torch. I had to lay on my back on a creeper and it was one of the nastiest jobs I ever did, great way to find out I didn't want an automotive career in my future... It did work just fine, but I would find a better way if I did it again.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1914932
09/18/15 11:35 AM
09/18/15 11:35 AM
Challenger 1
Cincinnati, Ohio
In 1976 or so my first "real" job was working at a British car and motorcycle dealer and he raced a Ford Cortina. One of my first jobs was to remove the undercoating from the car with a putty knife and a propane torch. I had to lay on my back on a creeper and it was one of the nastiest jobs I ever did, great way to find out I didn't want an automotive career in my future... It did work just fine, but I would find a better way if I did it again. I did it that way on 71 challenger I had around 1983, I got it off with torch and a putty knife, well most of it. I never did get the car back together and sold it and many NOS parts for it around 1988 to go drag racing. Man did I sell those NOS parts cheap compared to today. I sold them for more than I paid for them, thought I was doing good, it was still cheap.
[Re: Dons Dart]
#1914971
09/18/15 12:31 PM
09/18/15 12:31 PM
Posts: 5,949 British Columbia
chrisf
British Columbia
I remove this stuff often for customers. it doesn't have to be complicated and I don't think you need to spend hours with a pressure washer just to spend hours with a sander afterwards. media blasting has come a long way in the last few years and I am always amazed at people doing stuff the hard way to save $250 in blasting costs. that being said I blasted a rx7 for a customer yesterday and he did an awesome job at removing the undercoating before i blasted. I asked what he used and he said dry ice. put it on and the undercoating froze and he swept it off. dart
[Re: Dons Dart]
#1914987
09/18/15 12:43 PM
09/18/15 12:43 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
If the body is mounted on a rotisserie, under coating can be removed by sand blasting. As a bonus, the surface is clean and ready for sealer.
A mobile blaster charged me $600 to strip my '71 Challenger, top to bottom.
Make sure the blaster knows what he is doing, as sheet metal warps easily. The worst part is blowing out/vacuuming out residual sand. In my case, it wasn't too hard, as I cut the bottoms off the quarters ahead of time.
[Re: DoctorDiff]
#1915031
09/18/15 01:30 PM
09/18/15 01:30 PM
Challenger 1
Cincinnati, Ohio
Make sure the blaster knows what he is doing, as sheet metal warps easily. The worst part is blowing out/vacuuming out residual sand. In my case, it wasn't too hard, as I cut the bottoms off the quarters ahead of time. I like steam cleaning because like Scott said, I can see what the car looked like new. But the main reason for me is several, So I don't have a bare car to deal with while I make rust repairs, the car is still protected while I do sheet metal replacement. It's plenty clean enough to weld on with minor clean up at the weld area with a flap wheel. Then when all that is done then I'll media blast it, the whole thing right before paint. Saves me time and paint and grinding the primer off when I weld new sheet metal in. And then I only have to clean up media once and it sucks to have it in your frame rails when your trying to replace sheet metal on your car. Hate it on the floor of my shop. Plus you can't media blast stuff like glass and you can't media blast around window regulators in doors either like I did with hot water. I cleaned out the window regulator tracks with steam. And IMO media blasting off under coating causes much more stress on the metal than does steam cleaning, after steam cleaning it only takes a very light blasting to clean up. Less media and less to clean up too. I blasted a lot of my gold challenger after pressure washing the whole thing first. No oils got blasted into the metal or seams to come back later to haunt you because it was very clean before blasting. It took very little media, look on the ground and how close I am to my house, patio and garage. I used coal slag on the bottom and plastic media on the body. And I didn't media blast the doors or the inside of the front fenders, only steam cleaned them. There too delicate imo to be blasting, plus they were not rusty on my 71. Only one way to get them this clean...and not have a bare part rusting as soon as your done blasting needing primer.
[Re: Challenger 1]
#1915142
09/18/15 04:31 PM
09/18/15 04:31 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
That is true. Another thing is, I use my 100 cfm compressor that I use to blast with to blow out the car. Not my wimpy 5 horse shop compressor. i don't even waste my time blowing it out with a compressor.. i bought a stihl backpack blower for that task.
[Re: flypaper]
#1915281
09/18/15 09:16 PM
09/18/15 09:16 PM
Challenger 1
Cincinnati, Ohio
That is true. Another thing is, I use my 100 cfm compressor that I use to blast with to blow out the car. Not my wimpy 5 horse shop compressor. i don't even waste my time blowing it out with a compressor.. i bought a stihl backpack blower for that task. Heck yea! Bigger and badder is always better! I Got a stihl hand held yard blower, just got it a couple years ago. Don't know why I didn't have one sooner?=real handy. We have tons of leaves to deal with in the fall too and I did them with a rake for 25 years.
