Gasket Placement when installing a Thermostat #191347
01/12/09 11:42 AM
01/12/09 11:42 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
I have always been confused,and its not too hard to figure out.
I ve never been too sure of how to properly install a gasket when replacing a T-stat.
Does the gasket go down first,then the T-Stat then the t-stat housing...
OR
Does the T-Stat go down first,then the gasket,then the T-Stat housing.
OR
Does it not even really matter?
Re: Gasket Placement when installing a Thermostat [Re: SPWC] #191348
01/12/09 12:32 PM
01/12/09 12:32 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Stat goes into the recess in the housing attached to the upper hose then the gasket, this is then attached to the water pump/front cover housing. Bronze thermo sensor goes toward the engine.
Re: Gasket Placement when installing a Thermostat [Re: MoparforLife] #191349
01/12/09 12:40 PM
01/12/09 12:40 PM
NY usa
540challenger Offline
NY usa
it all depends on the intake and water outlet. Jusy check to make sure which one has the recess.
(sometimes they both have a recess)
Like mention before the thermostat goes into the recess then place the gasket down a bolt together.
i have seen people that put the gasket inbetween the recess and the thermostat and ton of gasket sealant all over the place becuse it leaked.
