72 E-body electrical ? #191318
01/12/09 10:37 AM
01/12/09 10:37 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Under the dash there are (3) 3 prong molds (yellow,orange & red) that you can plug a male terminal in.
Does anyone know what each one's purpose is ?
Re: 72 E-body electrical ? [Re: 340KID] #191319
01/12/09 11:28 AM
01/12/09 11:28 AM
Shoreline, Washington
72roadrunnergtx Offline
They are accessory power taps, as I recall, yellow is ignition/acc switched, red-unswitched, and orange being the dash illumination circuit.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 72 E-body electrical ? [Re: 72roadrunnergtx] #191320
01/12/09 03:06 PM
01/12/09 03:06 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yellow with tan wire is accesories source.
Red with pink wire is constant battery power source.
Both are fuse protected on fuse box.
Orange with orange wire is cluster dimmer source. Does have two fuses ( at least on B bodies ), one whet feeds the INPUT to lights switch and one that is OUTPUT from dimmer function, coming from same input
THERE IS ANOTHER ONE AROUND!!! Black with yellow wire. Is door jam switch ground
Re: 72 E-body electrical ? [Re: 72roadrunnergtx] #191321
01/12/09 04:57 PM
01/12/09 04:57 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
thanks
