Page 1 of 6 1 2 3 4 5 6
Trick Flow Mopar head #1912903
09/15/15 11:39 AM
09/15/15 11:39 AM
Tallmadge, Ohio
Trick Flow Offline OP
Tallmadge, Ohio
I just wanted everyone to know that the Power Port 240 head is now available to purchase and will be shipping within a week and a half!. Also, we want to thank everyone for their support and patience with us through this process. We're excited to be apart of the Mopar family!!!
PowerPort 240 Heads, CNC Street Ported Runners, Assembled
TFS-61617801-C00 1.460" dual valve springs, 240cc intake runners
TFS-61617802-C00 1.550" dual valve springs, 240cc intake runners
TFS-6161T783-C00 1.550" dual valve springs and titanium retainers, 240cc intake runners
TFS-6161T784-C00 1.560" dual valve springs and titanium retainers, 240cc intake runners
Re: Trick Flow Mopar head [Re: Trick Flow] #1912912
09/15/15 11:50 AM
09/15/15 11:50 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Are the intakes ready as well?
Re: Trick Flow Mopar head [Re: Trick Flow] #1912928
09/15/15 12:01 PM
09/15/15 12:01 PM
Tallmadge, Ohio
Tallmadge, Ohio
No, intakes are about 6 weeks out. We wanted to get the head finished and out first.
Re: Trick Flow Mopar head [Re: Trick Flow] #1912954
09/15/15 12:45 PM
09/15/15 12:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Can you provide more info on the spring specs that are used w/ the 6161T783-C00 and 6161T784-C00 versions? Thanks.
Re: Trick Flow Mopar head [Re: Trick Flow] #1912955
09/15/15 12:47 PM
09/15/15 12:47 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
are you going to both RB and low deck manifolds?
Re: Trick Flow Mopar head [Re: dartman366] #1912962
09/15/15 12:58 PM
09/15/15 12:58 PM
Tallmadge, Ohio
Tallmadge, Ohio
Yes, but the low deck version will most likely be after SEMA.
Re: Trick Flow Mopar head [Re: Trick Flow] #1912963
09/15/15 01:00 PM
09/15/15 01:00 PM
Tallmadge, Ohio
Tallmadge, Ohio
Here are the specs for the head.
Material: A356-T61 aluminum
Combustion Chamber Volume: 78cc CNC-profiled
Intake Port Volume: 240cc CNC Street Ported
Intake Port Location: Stock
Intake Port Dimensions: 2.270" x 1.230"
Intake Valve Diameter: 2.190"
Intake Valve Seat: Ductile iron
Exhaust Port Volume: 74cc CNC Street Ported
Exhaust Port Location: Stock
Exhaust Port Dimensions: 1.250" x 1.650" oval
Exhaust Valve Diameter: 1.760"
Exhaust Valve Seat: Ductile iron
Valve Angles: 15°
Valve Guide Material: Bronze alloy
Valve Seals: Viton® fluoroelastomer canister
Valve Seat Angles: 45° x multi-angle
Valve Spring Pocket Diameter: 1.615"
Valve Spring I.D. Locators: 1.300"
Valve Spring Retainers: Steel or titanium
Valve Stem Locks: 7° or 10° steel
Valve Springs, Standard: 1.460" o.d. dual spring with damper
120 lbs. @ 1.900" installed height
394 lbs. @ 1.175" open
390 lbs. per inch rate
.650" max. valve lift
Valve Springs, Option 1: 1.550" o.d. dual spring
138 lbs. @ 1.950" installed height
430 lbs. @ 1.250" open
420 lbs. per inch rate
.680" max. valve lift
Valve Springs, Option 2: 1.560" o.d. dual spring with damper
240 lbs. @ 2.000" installed height
600 lbs. @ 1.280" open
500 lbs. per inch rate
.700" max. valve lift
Rocker Arms: Roller rocker arms recommended
Re: Trick Flow Mopar head [Re: Trick Flow] #1913015
09/15/15 02:26 PM
09/15/15 02:26 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Is there a specific aftermarket rocker arm they work best with geometry wise?
Re: Trick Flow Mopar head [Re: Trick Flow] #1913026
09/15/15 02:44 PM
09/15/15 02:44 PM
Canada
Criterion Offline
Criterion  Offline
Canada
Well this has me super-stoked. It's been a long wait, but I am hopeful it was well worth it!
Re: Trick Flow Mopar head [Re: GTX MATT] #1913053
09/15/15 03:34 PM
09/15/15 03:34 PM
Tallmadge, Ohio
Tallmadge, Ohio
Any standard rocker arm will work, but Harland Sharp makes a short and a long. Our head will require their short rocker arm.
Re: Trick Flow Mopar head [Re: Trick Flow] #1913283
09/15/15 09:53 PM
09/15/15 09:53 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads?
Re: Trick Flow Mopar head [Re: 70RT Charger] #1913291
09/15/15 09:57 PM
09/15/15 09:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What`s the problem w/roller rockers you should run em anyways............... work
Re: Trick Flow Mopar head [Re: 70RT Charger] #1913315
09/15/15 10:17 PM
09/15/15 10:17 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Step away from the keyboard. Buy a set of Sidewinders, run your stock stamped rockers, and save your money and your brain cells.
Re: Trick Flow Mopar head [Re: 70RT Charger] #1913333
09/15/15 10:28 PM
09/15/15 10:28 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Reread his post. It says roller rockers recommended right after describing the .700 lift valve spring option.
Re: Trick Flow Mopar head [Re: 70RT Charger] #1913351
09/15/15 10:47 PM
09/15/15 10:47 PM
AndyF Online content
AndyF  Online Content
These are CNC ported heads so the average customer is going to want to run a much larger cam than stock to take advantage of the ported heads. If you want to use your stock cam and rocker arms then you should probably stick with a lower performance head such as the E street.
Re: Trick Flow Mopar head [Re: Trick Flow] #1913359
09/15/15 11:05 PM
09/15/15 11:05 PM
eastern,Ky
eastern,Ky
Since it didn't say nothing about Rocker Arms until the very last I assumed it they recommended rollers period. Andy the cam I was going to use was a 232-238 grind and 514/532 hydraulic I think. I was still wanting it to be very streetable and make long trips but would like the extra hp these heads bring also and run a dual plane intake also. I really wasn't wanting to buy the roller now but if I had to I would break down and buy them. What are sidewinders?
Re: Trick Flow Mopar head [Re: Trick Flow] #1913513
09/16/15 07:10 AM
09/16/15 07:10 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
According to the summit webpage estimated shipping date is one month+ (10/19) if ordered today. A little more than the announced 10 days. Any further delays to be expected?
Re: Trick Flow Mopar head [Re: DGS] #1913558
09/16/15 10:47 AM
09/16/15 10:47 AM
Tallmadge, Ohio
Tallmadge, Ohio
Don't go buy the date that Summit has posted. Those are computer generated dates and are not actual, at least on our products.
Re: Trick Flow Mopar head [Re: 70RT Charger] #1913559
09/16/15 10:48 AM
09/16/15 10:48 AM
Tallmadge, Ohio
Tallmadge, Ohio
Roller rocker arms are recommended (not mandatory) due to the increased spring pressures.
Re: Trick Flow Mopar head [Re: Trick Flow] #1913569
09/16/15 11:15 AM
09/16/15 11:15 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Makes me wish I had a big block.
Yeah, it's got a smallblock.
