Re: Trick Flow Mopar head
[Re: Trick Flow]
#1912954
09/15/15 12:45 PM
09/15/15 12:45 PM
BradH
TFS-6161T783-C00 1.550" dual valve springs and titanium retainers, 240cc intake runners TFS-6161T784-C00 1.560" dual valve springs and titanium retainers, 240cc intake runners
Can you provide more info on the spring specs that are used w/ the 6161T783-C00 and 6161T784-C00 versions? Thanks.
[Re: Trick Flow]
#1912955
09/15/15 12:47 PM
09/15/15 12:47 PM
dartman366
Mt. Vernon, Ohio
are you going to both RB and low deck manifolds?
[Re: Trick Flow]
#1913015
09/15/15 02:26 PM
09/15/15 02:26 PM
Posts: 5,161 CT
GTX MATT
CT
Is there a specific aftermarket rocker arm they work best with geometry wise?
[Re: GTX MATT]
#1913053
09/15/15 03:34 PM
09/15/15 03:34 PM
Posts: 13 Tallmadge, Ohio
Trick Flow
Tallmadge, Ohio
Is there a specific aftermarket rocker arm they work best with geometry wise? Any standard rocker arm will work, but Harland Sharp makes a short and a long. Our head will require their short rocker arm.
[Re: Trick Flow]
#1913283
09/15/15 09:53 PM
09/15/15 09:53 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads?
[Re: 70RT Charger]
#1913291
09/15/15 09:57 PM
09/15/15 09:57 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads? What`s the problem w/roller rockers you should run em anyways...............
[Re: 70RT Charger]
#1913315
09/15/15 10:17 PM
09/15/15 10:17 PM
Posts: 610 long time lurker, short time p...
PorkyPig
You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads? Step away from the keyboard. Buy a set of Sidewinders, run your stock stamped rockers, and save your money and your brain cells.
[Re: 70RT Charger]
#1913333
09/15/15 10:28 PM
09/15/15 10:28 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads? Reread his post. It says roller rockers recommended right after describing the .700 lift valve spring option.
[Re: DGS]
#1913558
09/16/15 10:47 AM
09/16/15 10:47 AM
Trick Flow
Tallmadge, Ohio
According to the summit webpage estimated shipping date is one month+ (10/19) if ordered today. A little more than the announced 10 days. Any further delays to be expected? Don't go buy the date that Summit has posted. Those are computer generated dates and are not actual, at least on our products.
[Re: 70RT Charger]
#1913559
09/16/15 10:48 AM
09/16/15 10:48 AM
Trick Flow
Tallmadge, Ohio
You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads? Roller rocker arms are recommended (not mandatory) due to the increased spring pressures.
[Re: Trick Flow]
#1913569
09/16/15 11:15 AM
09/16/15 11:15 AM
Posts: 1,532 off the grid
340B5
off the grid
Makes me wish I had a big block.
Yeah, it's got a smallblock.
