How to replace a Front Floor Pan? #191287
01/12/09 10:13 AM
01/12/09 10:13 AM
Louisiana
duckblind Offline OP
Louisiana
I need to replace the front floor pans on my 68 charger but want to do so without taking the car apart. I recently purchase a full front floor pan, including the hump. My basic plan is to cut the pan in two pieces so that I could get it in through the door and then weld it back together. Has anyone ever done this? Is this a crazy idea? Does anyone have any tips? Should I cut the pan parrallel or perpendicular to the hump?
Thanks,
Jason
Re: How to replace a Front Floor Pan? [Re: duckblind] #191288
01/12/09 11:27 AM
01/12/09 11:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Does your hump need replacing? If not, I would consider keeping it in place as a reference to location, and like you say smaller pieces are easier to work with.
Re: How to replace a Front Floor Pan? [Re: duckblind] #191289
01/12/09 06:15 PM
01/12/09 06:15 PM
yes, you're crazy!
Re: How to replace a Front Floor Pan? [Re: duckblind] #191290
01/13/09 08:10 AM
01/13/09 08:10 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
I cut out both sides of mine and welded in the new pans. I have several pictures in my signature site. If you look at the painted floor after it is hard to tell they were replaced from the bottom or top.Look under quarter panel replacement and floor removal. Good Luck
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
