Re: Cal track launch pic.
[Re: Clanton]
#1912843
09/15/15 09:58 AM
09/15/15 09:58 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
So what did it run at Norwalk?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: justinp61]
#1912864
09/15/15 10:43 AM
09/15/15 10:43 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Do you have a photo of the car at rest? I will get 1.I am shopping for a shifter looking at a Precision performance 1.I was using the factory console shifter.
[Re: Clanton]
#1913202
09/15/15 07:43 PM
09/15/15 07:43 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Clanton , it looks similar to my satellite on launch . You may have to tighten up the rear extension some more . How much front end lift is available ? Getting the best front rise may be difficult with the weight of the blower . Most people watching mine say it looks like the whole car lifts vertically then leaves
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Clanton]
#1913279
09/15/15 09:48 PM
09/15/15 09:48 PM
tex013
Sydney,Australia
I have stock rear shackles and XHD springs . The Caltrac will force the separation . As long as you are not spinning should be ok . Front travel @ 5" should be fine . Picture does not show a lot of lift at front , but this could be like I said the extra weight on front . Could even be your shocks - I have QA1 single adjust on front , Rancho 9 way on rear . Rear set 1 click off full tight extension , front to full loose .Oh I also removed a couple of spring clamps on the rear half as well, similar to how superstock springs are
Tex
[Re: Clanton]
#1913460
09/16/15 01:25 AM
09/16/15 01:25 AM
Thumperdart
State of confusion
The problem I had was in the shifter linkage and that changes a lot of things like I can move my seat back some and I will be able to reach the new shifter moved back 2".I have things to do over winter now.The shifter is over due. Man, I feel for ya and know you`ve been fighting that car for a while now and hopefully you can get it together. I agree about the shackles in the rear and limiting separation and getting as much front end transfer as possible being it`s very nose heavy. Good luck man........
[Re: Quicktree]
#1913945
09/16/15 07:17 PM
09/16/15 07:17 PM
Clanton
northern,Ohio,USA
love the car, but how come you have it setting so high up? I can lower the front but the back is for tire clearance.[stock wheel well w/10.5x29.5 tire]
[Re: Clanton]
#1914030
09/16/15 09:38 PM
09/16/15 09:38 PM
Quicktree
love the car, but how come you have it setting so high up? I can lower the front but the back is for tire clearance.[stock wheel well w/10.5x29.5 tire] the very first thing I would do is fix that issue. mini tub or what ever it takes. if not you have an uphill battle imo.
