Clutch recommendation? #1912803
09/15/15 05:44 AM
09/15/15 05:44 AM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
As expected my single disc clutch is giving up behind my 500 cubic low deck stroker and I'm looking into a dual disc set up with some more holding capacity. What would you guys recommend?
I'm looking at the Ram Clutches Force 10.5, McLeod RXT and or the Centerforce DYAD dual disc that is rated at 1300 ft/lbs torque. This car is mostly driven on the street with street tires.
Please let me know what you think.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Clutch recommendation? [Re: cudaerik] #1912879
09/15/15 11:14 AM
09/15/15 11:14 AM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
What clutch do you have now, out of curiosity?
Re: Clutch recommendation? [Re: GTX MATT] #1912905
09/15/15 11:41 AM
09/15/15 11:41 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We carry all of the Mcleod packages:
http://brewersperformance.com/products.asp?cat=240
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Clutch recommendation? [Re: cudaerik] #1912909
09/15/15 11:48 AM
09/15/15 11:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run the CF dual friction clutch.My 440 built pushes 600HP.Been in for years and still like new.Hooks super and light pedal.Mine sees lots of street and some strip.Rocky
Chrysler Firepower
Re: Clutch recommendation? [Re: therocks] #1913155
09/15/15 05:48 PM
09/15/15 05:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We've installed a lot of CF's in a lot of different applications with no issues twocents
Re: Clutch recommendation? [Re: cudaerik] #1913189
09/15/15 07:04 PM
09/15/15 07:04 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Centerforce in my Duster, I love it.
Re: Clutch recommendation? [Re: dustergirl340] #1913234
09/15/15 08:31 PM
09/15/15 08:31 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Another vote for Centerforce. up drive
Re: Clutch recommendation? [Re: cudaerik] #1913383
09/15/15 11:28 PM
09/15/15 11:28 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I called Centerforce when I was in the market for a clutch for my street driven 69 RR that weights 3900lbs plus driver. I built a 499 cube stroker that made 500hp/550tq. They said for that weight they only recommended the dual disc and not the dual friction.
I ended up buying the Mcleod RST twin disc. It wasn't cheap! I had to drive the car normally for 500 miles. Once or twice I felt it slip aafter breakin.
After 3000 miles I pulled it apart because I am redoing my motor. I do see a few hot spots. Mcleod thinks it's normal wear. I am not sure.
The pedal feels amazing, very light and no chatter. If I do it again I would probably try the dual friction.
