Blower motor wiring question. #1912660
09/14/15 11:49 PM
09/14/15 11:49 PM
MN
Skid_Demon Offline OP
MN
Looks to be a 12 fan motor in an old 6 volt heater core. The old square type in old trucks that mount under the dash. There are three wires. The green one goes to the switch. Red and yellow are joined with a wire nut. If yellow and red are seperated the motor stops. Fan spins like crazy. Any way to slow the fan motor? Thanks.
Re: Blower motor wiring question. [Re: Skid_Demon] #1912764
09/15/15 01:52 AM
09/15/15 01:52 AM
you might ohm the red and yellow wires to the case and see what you get
