Float height for brass versus plastic
#1912500
09/14/15 09:52 PM
09/14/15 09:52 PM
Posts: 89 Huntsville, AL
JohnD
Huntsville, AL
My TQ rebuild is almost finished and I'm ready to adjust float height. I have new plastic floats to replaced the leaking original brass versions. The service manual shows a 1" height for the brass floats. Should I use that for the new set?
1971 Road Runner 340
Re: Float height for brass versus plastic
[Re: JohnD]
#1912767
09/15/15 02:00 AM
09/15/15 02:00 AM
RapidRobert
The service manual shows a 1" height for the brass floats. Should I use that for the new set? sounds like a logical Q to me. For the sake of uniformity that even tho they are of different material & diff material has a different bouyancy that they shaped both of em so that when you set em to 1" the resulting end result fuel level (the bottom line) is the same. I would call "the carburetor shop" in Eldon Missouri (Google it). he sells premium ($$$) kits & even mfrs rods/jets for his carb kits & he'd likely have no problem answering a quick Q regarding this
[Re: JohnD]
#1912966
09/15/15 01:01 PM
09/15/15 01:01 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Thanks If it is 1" ,it is what it is regardless of what it's made from !
[Re: stumpy]
#1913070
09/15/15 03:52 PM
09/15/15 03:52 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
stumpy]Yes. Floats don't care what they are made of. LOL Hmm Stumpy, no offense meant but, lets say one has a ship made of something heavy like IRON, lets also say that the same ship made out of hollow plastic. Would it take more of the same liquid to float the iron ship or the plastic one ??? Not sure myself but just asking ?? Again Dunno [/quote] That has absolutely nothing to do with carb floats. Stick to the subject. Really? Holley tech article
