Max Wedge hood scoop. Correct location? #1912360
09/14/15 05:40 PM
09/14/15 05:40 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I am installing a Max Wedge scoop on a 64 Plymouth Belvedere. Does anyone have pictures or dimensions of the proper placement. A measurement from the rear edge of the hood would be nice. Thanks
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1912376
09/14/15 06:06 PM
09/14/15 06:06 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
there is a guy on ebay that sells a template it works well
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1912458
09/14/15 08:19 PM
09/14/15 08:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I found this with a quick google search of the site
https://board.moparts.org/ubbthreads/ubbt...-placement.html
Gus beer
64 Plymouth Savoy
Dana 60
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1912543
09/14/15 09:26 PM
09/14/15 09:26 PM
Canada
demon Offline OP
demon  Offline OP
Canada
thanks. That helps. I have seen some quite a bit further back too.
Re: Max Wedge hood scoop. Correct location? [Re: fourgearsavoy] #1912754
09/15/15 12:39 AM
09/15/15 12:39 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's an original, both hood and scoops were all aluminum.
Reproduction steel Max Wedge Scoop On Car.jpg64 Max Wedge Scoop Front On car.jpg
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1912804
09/15/15 05:44 AM
09/15/15 05:44 AM
Canada
demon Offline OP
demon  Offline OP
Canada
That's the best picture I have seen yet. Thanks!!
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1913943
09/16/15 06:14 PM
09/16/15 06:14 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Any other pictures or measurements guys?
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1913974
09/16/15 06:50 PM
09/16/15 06:50 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Thought the middle was down on hood, not spaced up?
Re: Max Wedge hood scoop. Correct location? [Re: demon] #1914088
09/16/15 10:00 PM
09/16/15 10:00 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have a factory Ali front 63 Belv at home I will measure it for you.
They were spaced up just not as much as the above shot, below is correct.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Max Wedge hood scoop. Correct location? [Re: ozymaxwedge] #1914112
09/16/15 10:31 PM
09/16/15 10:31 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Yes, looks better, I suppose most where opened up to get more air
