68 Satellite quarter window removal
#191231
01/12/09 12:38 AM
01/12/09 12:38 AM
I have the body of the 68 almost completely stripped all that's left is the 1/4 windows and trim. Can someone please tell me how to remove them safely? It's a non post car.
Re: 68 Satellite quarter window removal
#191232
01/12/09 10:35 AM
01/12/09 10:35 AM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
There are 2 bolts that hold the glass to the regulator. After the back seat is out and the arm rest and window crank handle are removed, pop off the side panel and remove the screws holding the chrome strip and the metal upper panel. Remove the plastic, slip the window crank back on and roll the window to where you can get to the 2 bolts with a socket and extension. Good luck!
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
[Re: johnedod]
#191233
01/12/09 06:34 PM
01/12/09 06:34 PM
Thanks. Sounds easy enough.
Now for the hard part...How do I get the crank assembly out? Just take out all of the bolts and it will come out? or is there a trick to it?
#191234
01/12/09 09:39 PM
01/12/09 09:39 PM
johnedod
Clintwood VA
Well, I didn't take the back regulators out of mine, so I can't really help you there. I noticed there was a lot of fore and aft and in and out adjustment on everything so I just left mine in there. Everything does just bolt in, but if it were me I'd find some way to mark everything to get it back close to where it was. I'd also take some pics before taking it apart. If you are going to change 1/4 panels I'd cut the old 1/4s off first, then you can see everything a lot better. Once you get in there you'll understand it a lot better.
[Re: belv2vert66]
#191237
01/14/09 12:23 AM
01/14/09 12:23 AM
Sounds like tons of fun. I am going to be sand blasting it. Maybe I should just take the glass out and some how mask them off the best I can?
