anyone knows about Viper engines?
#1912060
09/14/15 06:20 AM
09/14/15 06:20 AM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
Hi,
a friend of mine has a 95 Viper where the con rods let go. everything is toast now including the block. Anyone an idea where to get a NEW engine? I see 2003 and up crates on Ebay, but do they interchange, particularly all the electronical gismos?
I see Comp Cam lists 1992 to 2002 as the same cams being the same? Does the whole long block change over from 1992 to 2002?
If no new ones are available, who offers reliable rebuilt Viepr engines?
Greets Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
Re: anyone knows about Viper engines?
[Re: Flo]
#1912080
09/14/15 09:46 AM
09/14/15 09:46 AM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
He needs to look for a Gen 1 Viper engine. The 1992 through 1996 Viper R/T-10 used the Gen 1 engine. It's a wet sleeve block design and prone to head gasket problems. It's an OBD 1 engine. The 1996 through 2003 Viper GTS Coupe used what's call the Gen 2 engine which is a dry sleeve block design and is OBD2 compliant. The electronics are completely different between the two and the reason why it's not a direct swap. The online Viper forums would be a good place to look for an engine. viperclub.org viperclub.org or He needs to look for a Gen 1 Viper engine. The 1992 through 1996 Viper R/T-10 used the Gen 1 engine. It's a wet sleeve block design and prone to head gasket problems. It's an OBD 1 engine. The 1996 through 2003 Viper GTS Coupe used what's call the Gen 2 engine which is a dry sleeve block design and is OBD2 compliant. The electronics are completely different between the two and the reason why it's not a direct swap. The online Viper forums would be a good place to look for an engine. viperclub.org or viperalley.com
[Re: Flo]
#1912108
09/14/15 11:13 AM
09/14/15 11:13 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I have a new wet sleeve alum Viper block I had intended to build a coffee table out of, but its way down on my list of projects. I would assume there are others out there if a rebuild is the plan.
[Re: Flo]
#1912154
09/14/15 12:23 PM
09/14/15 12:23 PM
Flo
Berlin, Germany
The one in Ca sounds like a really god deal!
I could arrange the whole shipping to Europe- I have a US address.
Does anyone know if the con rods on those were a weak spot? The motor only ahd around 20k mls on it and a rod lets go? Had the stock ECU with rev limiter (being a 1995 it has one, right?)
[Re: Flo]
#1912169
09/14/15 12:44 PM
09/14/15 12:44 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The one in Ca sounds like a really god deal! Does anyone know if the con rods on those were a weak spot? The motor only ahd around 20k mls on it and a rod lets go? Had the stock ECU with rev limiter ( it has one right?) In the historical book "Chrysler Engines" the author, retired chief engineer of Chrysler Willem Weertman discusses the birth of the aluminum Viper V10 and iron block pickup V10. I am 99% certain he writes that as a cost saving move the V10s used the same hyper eutectic aluminum alloy piston as the already in production 1993+ Magnum 5.9 V8. I am not more than 50% certain if this meant only the iron block V10. If they used the piston they may have also used the con rod. Another book by an ex Chrysler employee Jim Szilagyi entitled "How to Build Big Inch Chrysler Small Block Engines" he writes that 2000-2001 year Viper connecting rod PN P5007504 is approximately 0.098 inch longer (total length 6.221) but has a small pin bore (0.9425 to 0.9440 inches) and can be used to help zero deck SB Magnum V8s. The Magnum connecting rod is lightened by 14 grams on the small end compared to the LA 360 but is still considered a relatively stout design.
[Re: Flo]
#1912253
09/14/15 02:56 PM
09/14/15 02:56 PM
Flo
Berlin, Germany
I think piecing this block back together and remachining it might cost more than a crate off of Craigslist.... + would have unpredictable results...
[Re: Flo]
#1912296
09/14/15 04:16 PM
09/14/15 04:16 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
At one point in time roughly 50% of Vipers built were totaled. Should be no shortage of low-mile complete engines in the Viper-specific wrecking yards.
[Re: SNK-EYZ]
#1912735
09/15/15 12:55 AM
09/15/15 12:55 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Is there any reason he can't buy a newer block and use the older heads/intake to use the original electronics? I know that between an OBD-1 95 5.9 and a OBD-2 96 5.9, the block, heads, etc are all the same.
**Photobucket sucks**
[Re: 70Cuda383]
#1912765
09/15/15 01:59 AM
09/15/15 01:59 AM
SNK-EYZ
A Red State
Is there any reason he can't buy a newer block and use the older heads/intake to use the original electronics? I know that between an OBD-1 95 5.9 and a OBD-2 96 5.9, the block, heads, etc are all the same. It will need someone more familiar with the differences are to say what will interchange. Maybe a Viper Tech can answer those. There's a local guy Joe Donovan that runs a performance shop http://www.performancebyjoe.com . He was a Viper Tech at a Dodge Dealership 10 years ago. He may have some idea.
