Re: Electrical Problems
[Re: jeebis44]
#1911793
09/13/15 07:34 PM
09/13/15 07:34 PM
Posts: 5,919 ohio
ruderunner
ohio
Poor ground for reg, poor voltage siginal to regulator or not unlikely a bad reg. 16 at idle is too high, probably goes higher with some rpm, maybe 18.
Angry white pureblood male
[Re: jeebis44]
#1911932
09/13/15 11:05 PM
09/13/15 11:05 PM
RapidRobert
high(er) RPM may have increased the electrical demand & reduced the full fielded output from 16 to 15 or something changed a bit inside the alt (where I think the prob is). Might be a bad (new) reg and or the alt field circuit may have grounded at the right place to full field it (which might be the problem in the first place. Subbing in another alt from your stash or another vehicle (no one "on here" has just one) but as you know I believe the Leece Neville alt has a unique mounting
[Re: RapidRobert]
#1911944
09/13/15 11:20 PM
09/13/15 11:20 PM
Posts: 1,822 Colorado
denfireguy
Colorado
What Robert said. I would lean to a short in the alternator with the field on one end grounded and the other end going to 12 volts putting it max output all the time. Put your meter on each field connection. One should be 12 volts. Leave it alone. The other should be low, 0 to 2 or three volts. Pull that wire off. That should kill the output of the alternator. If it does not, there is a short in the alternator and it needs to be replaced. If that did not affect it, then it is in the regulator or the wiring. Since the wiring runs along the top of the engine, wires get baked and brittle. The insulation flakes off and you have a run away alternator. Or worse, 12 volts goes to ground with other issues so check there as well. Let us know what you find. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1911957
09/13/15 11:30 PM
09/13/15 11:30 PM
RapidRobert
Pull that wire off. That should kill the output of the alternator. If it does not, there is a short in the alternator and it needs to be replaced. If that did not affect it, then it is in the regulator or the wiring. Correct, pull the green field wire at the alt & if it is still charging then it is the alt & first do a visual on the brush/brush holder assy
[Re: jeebis44]
#1912294
09/14/15 04:10 PM
09/14/15 04:10 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
1982 Plymouth Gran Fury - 318 w/ 114 amp cop alt The OP likely has the Leece-Neville alternator which wires the same as the Mopar single-field alternator.
