Anybody know how much cfm a 4" throttle body flows? #191191
01/12/09 12:02 AM
01/12/09 12:02 AM
Las Vegas NV
moparmanjames Offline OP
Las Vegas NV
?? I couldnt find a flowchart, thanks.
Re: Anybody know how much cfm a 4" throttle body flows? [Re: moparmanjames] #191192
01/12/09 01:21 AM
01/12/09 01:21 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Re: Anybody know how much cfm a 4" throttle body flows? [Re: formula S] #191193
01/12/09 02:05 AM
01/12/09 02:05 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Accufab Fmax 105mm flows 1504 CFM
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Anybody know how much cfm a 4" throttle body flows? [Re: go green] #191194
01/12/09 09:50 AM
01/12/09 09:50 AM
Las Vegas NV
Las Vegas NV
Thanks guys, I was guessing about 1500 but wasn't sure.
The setup I'm looking at now has 2 Gaerte/Kinsler
4" TB's with some of the plumbing like the Kinsler metering/distribution block and injectors but it doesn't have a pump. I don't know if I should jump on it for $1000 or leave it alone.
What do you guys think?
Re: Anybody know how much cfm a 4" throttle body flows? [Re: moparmanjames] #191195
01/12/09 01:49 PM
01/12/09 01:49 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Does it have the barrel valve? You'll need a pump, mounting brackets, either a crank drive mandrell, or a cam drive unit, a 3-way shutoff valve, and then send the whole works off to get it flowed to match your motor. If the current owner has the info off his motor, including what pump he was using iand what it flowed, $1000 may not be a bad price.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Anybody know how much cfm a 4" throttle body flows? [Re: moparmanjames] #191196
01/12/09 04:33 PM
01/12/09 04:33 PM
NC
440Jim Offline
440Jim  Offline
NC
The conclusion I came to when looking at a used system was to price out ALL the costs to get it going on your car. Then compare to buying a new system all setup for your application. Most I looked at didn't save as much money as I had hoped, considering you have used rather than new stuff.
IMO, about 60% of new is about right. Otherwise buy the new system for a few hundred more. The parts add up fast, especially if you need to recalibrate. Talk to the distributor for parts costs, and calibration. For example the current pump from Ron's (durable black gear) is $485. If you buy a used one and it craps out, $$$.
Re: Anybody know how much cfm a 4" throttle body flows? [Re: Slingshot383] #191197
01/12/09 04:39 PM
01/12/09 04:39 PM
Las Vegas NV
Las Vegas NV
I don't know if it has a barrel valve or not. The current owner bought it used and doesn't know much about it other than it was on a tractor puller called "Fire Dragon" lol. So it's probably a little more than I need, ha.
Re: Anybody know how much cfm a 4" throttle body flows? [Re: 440Jim] #191198
01/12/09 04:48 PM
01/12/09 04:48 PM
Las Vegas NV
Las Vegas NV
True, maybe it's time to just look at a Dominator carb setup.
