Re: Radiator Overflow Bottle options?
[Re: WO23Coronet]
#1911802
09/13/15 07:58 PM
09/13/15 07:58 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I used the Dorman reservoir #603-12.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: WO23Coronet]
#1911857
09/13/15 09:25 PM
09/13/15 09:25 PM
Posts: 43,211 Bend,OR USA
Cab_Burge
When NHRA fisrt required them, 1 pint over flow reservoirs, we used a empty one quart Pennzoil gear grease bottle, a peice of rubber hose over the overflow nipple on the radiator down into the bottle and we went racing I did use a platsic zip tyerap to hold it onto the radiator support when sitting on top of the passneger side front subframe that always got us through tech. at every track we raced at out west
[Re: Cab_Burge]
#1911921
09/13/15 10:50 PM
09/13/15 10:50 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I purchased one of the hot rod cans from summit or jegs.. Installed it between my radiator and the grill.. Have to look for it to see it... NO problems since I installed it..
[Re: WO23Coronet]
#1912050
09/14/15 02:59 AM
09/14/15 02:59 AM
Posts: 566 WA
tman
WA
[Re: YO7_A66]
#1912072
09/14/15 08:39 AM
09/14/15 08:39 AM
YO7_A66
Indiana
(To answer a couple of my PM's)
Using the picture in my above post, you can see a brass insert in the "snout" of the reservoir. I pulled it out (lightly slipped into the plastic) and tapped the hole for a barbed fitting/bushing. I don't recall if I tapped it for an 1/8 or a 1/4 fitting. But the hole was perfect for one of those sizes. I just tapped it out for the NPT fitting and used sealant on the threads of the fitting. I then let it dry and then ran the overflow rubber hose from the cap to this fitting. Then there is another overflow fitting on the top of the cap that I added another rubber hose too and ran it to the ground.
I was surprised on how much more coolant the system took once I filled the reservoir. I had to keep topping it off to the point that I thought it had a leak. It works great and it passes coolant back and fourth as needed. I used a Vented 16lb cap. You can see how much lower the reservoir sits than the top of the radiator.
[Re: AndyF]
#2356632
08/19/17 04:07 PM
08/19/17 04:07 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
That Dorman one looks good. I used one from a Toyota 4Runner. The 4Runner unit is a simple rectangular design that fits really well next to the radiator. It has a tube that goes down below water level so the overflow is pulled back into the radiator as the water cools down.
Old thread revival: Andy - Do you have any pictures showing the 4runner overflow in your car? Looking to get an idea of how deep it is. Dorman only lists w & h for their repop. Plus my experience is that their dimensions can not be relied on as sometimes they are package dimensions rather than product.
[Re: Mattax]
#2357135
08/20/17 02:47 PM
08/20/17 02:47 PM
Posts: 31,045 Oregon
AndyF
Old thread revival: Andy - Do you have any pictures showing the 4runner overflow in your car? Looking to get an idea of how deep it is. Dorman only lists w & h for their repop. Plus my experience is that their dimensions can not be relied on as sometimes they are package dimensions rather than product. Here is a picture of the 4Runner setup on my Coronet. It fit really nice in the space I have but mounting it was a bit of a trick. Dorman sells a replacement bottle for this application or you can hit the wrecking yards. You can also buy them new from the Toy dealer but they are super expensive.
[Re: Mattax]
#2359881
08/25/17 09:12 PM
08/25/17 09:12 PM
Mattax
Phila. Pa.
Here's the Dorman 603325 installed. Had to make my own mounting. Tried to stiffen the bracket up but the bottle still moved a little because of the way it attaches. Any movement is too much for what I'm doing. Fixed that with a tie-wrap at the top.
