Re: 727 bellhousing -
[Re: shakerjoe]
#1911290
09/12/15 09:51 PM
09/12/15 09:51 PM
Posts: 5,914 ohio
ruderunner
ohio
Sounds fixable. Find a welder that cxan do tig.
Angry white pureblood male
[Re: shakerjoe]
#1911327
09/12/15 10:42 PM
09/12/15 10:42 PM
Posts: 25,903 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Lots of people used to (or maybe still do) cut that area out to make it easier to install/tighten the converter bolts. I've seen square and arced cuts that go back a couple inches from the face of the bellhousing.
Not much stress in that area, if welding isn't convenient just stop drill the crack and call it good or cut out the entire area.
[Re: shakerjoe]
#1912414
09/14/15 08:05 PM
09/14/15 08:05 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
Weld it up, dress it, then sandblast the case in that area and you'll be good to go. I've done it a number of times including welding holes shut.
[Re: shakerjoe]
#1919943
09/26/15 09:09 AM
09/26/15 09:09 AM
Posts: 5,914 ohio
ruderunner
ohio
The one by the bottom of the Bell is definitely a crack. The one by the pump looks more like a casting mark. Notice it doesn't go into the machined area of the pump opening.
What do things look like from outside the Bell? The one crack will definitely show on the outside. The casting mark won't.
[Re: shakerjoe]
#1920178
09/26/15 06:44 PM
09/26/15 06:44 PM
John_Kunkel
Rio Linda, CA
Very strange crack. As I stated earlier this isn't a highly stressed area. I'd scrap it.
[Re: shakerjoe]
#1920231
09/26/15 08:11 PM
09/26/15 08:11 PM
John_Kunkel
Rio Linda, CA
Numbers matching changes the game. Welding is the only way to save it.
