battery disconnect vs computers #1911102
09/12/15 03:21 PM
09/12/15 03:21 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
In more modern cars with computers managing engines and transmissions how much risk of losing data is there if you have a battery disconnect and leave it disconnected for long periods of time?????
Driving modern convenience in classic beauty
Re: battery disconnect vs computers [Re: Darius] #1911154
09/12/15 04:49 PM
09/12/15 04:49 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
When the computer is disconnected from battery power it can forget it's history and any engine/transmission tuning parameters which will cause it to default back to it's baseline setting.
If you're in a state where you have emissions testing, the computer forgets this stuff w/o battery power and you have to go through several drive cycles for the computer to verify everything is working fine.
I wouldn't think there is any risk of hurting anything if you don't mind the computer taking time/miles to relearn what it needs.
Re: battery disconnect vs computers [Re: Darius] #1911190
09/12/15 06:23 PM
09/12/15 06:23 PM
Andrewh Offline
Andrewh  Offline
for my car because I don't use it very much I put it on a battery tender like my classic car. they even make solar ones if you don't have access to a plug.
Re: battery disconnect vs computers [Re: Andrewh] #1911237
09/12/15 08:01 PM
09/12/15 08:01 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I agree with Andrew on the battery tender because it's better for your battery to keep the plates activated. The power accessories like sunroofs and power windows will need to be re-initialized on some modern cars.You may also have to clean the throttle body and re-learn the throttle motor as well every time you disconnect the battery or it will idle about 400 RPM.
Gus beer
64 Plymouth Savoy
Dana 60
Re: battery disconnect vs computers [Re: fourgearsavoy] #1911331
09/12/15 10:54 PM
09/12/15 10:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Ten bucks says that Darius is referring to the 5.7 swap setup in his GTX.
Re: battery disconnect vs computers [Re: Kern Dog] #1911639
09/13/15 01:32 PM
09/13/15 01:32 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
How "observant" of you;-)! Somewhere in this car is a microscopic draw on the battery. Until I can track it down I thought a disconnect would save the battery. I do have a good trickle charger and I will keep that hooked up but I was thinking safer than sorry if I am on a trip and don't have an outlet available, not to mention one more security device....although, one would probably NOT be able to hotwire this car very easily if at all.
Re: battery disconnect vs computers [Re: Darius] #1911805
09/13/15 08:00 PM
09/13/15 08:00 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You won't lose any long term data by disconnecting the battery with any reasonably modern ECU. If your swap is a Mopar ECU, you might lose some adaptations to fuel trims, which will solve itself soon after getting on the road.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: battery disconnect vs computers [Re: Darius] #1911885
09/13/15 10:13 PM
09/13/15 10:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are you sure the microscopic draw isn't the ECU?
Kevin
Re: battery disconnect vs computers [Re: Twostick] #1912078
09/14/15 09:44 AM
09/14/15 09:44 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Kevin
I am NOT sure that is not the case but is something I will look at for sure.
Re: battery disconnect vs computers [Re: Darius] #1912233
09/14/15 02:09 PM
09/14/15 02:09 PM
dogdays Offline
dogdays  Offline
Or the solar powered charger that you stick on the dashboard and plug into the lighter socket, as mentioned above. I have seen them for as little as $20.
R.
