Re: Are my belts and pulleys correct?
[Re: BigAg]
#1909451
09/09/15 07:48 PM
09/09/15 07:48 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
They look normal to me.
Some cars had belt tensioners but most of mine did not.
My Imperial has the AC compressor hugging the left head and the alternator a bit farther right than yours. The two belts jump that span without a tensioner or idler. If they're not perfectly matched they will come off with enthusiastic driving.
[Re: BigAg]
#1909460
09/09/15 08:02 PM
09/09/15 08:02 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do I need this or do you keep the belts tight by putting pressure on the alternator and power steering pump while you tighten the bolts? You'll notice that the P/S bracket has a 1/2" square hole near the pivot bolt, this is for a 1/2" drive breaker bar to apply tension to the bracket to tension the belt while tightening the bolt(s). The alternator belt is tensioned by merely grabbing the bottom of the alternator and pulling up/outboard while tightening the bolt(s). Belt alignment is best checked with a straight edge against the face of the WP pulley sheave...the belt might be more aligned in the rear alternator pulley sheave...straight edge will tell.
[Re: John_Kunkel]
#1909470
09/09/15 08:19 PM
09/09/15 08:19 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
You'll notice that the P/S bracket has a 1/2" square hole near the pivot bolt, this is for a 1/2" drive breaker bar to apply tension to the bracket to tension the belt while tightening the bolt(s). i learn something every day......
[Re: BigAg]
#1909883
09/10/15 01:20 PM
09/10/15 01:20 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
You might want to also round up the spacer that goes between the alternator and the head. Without it you can mess up the alternator when the pivot bolt is tightened.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: BigAg]
#1909888
09/10/15 01:32 PM
09/10/15 01:32 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Alt belt might line up better on the back groove.It looks like its off.The spacers can be a pain.With stuuf being changed over years you sometimes have to play with them to get align right.Rocky
Chrysler Firepower
[Re: BigAg]
#1910118
09/10/15 08:11 PM
09/10/15 08:11 PM
therocks
Niles , Ohio
I have double on my single pulleys.My 440 sees 6500 all the time.Never tossed a belt in 15 years.I did play with the spacers.Rocky
Chrysler Firepower
[Re: BigAg]
#1911110
09/12/15 03:30 PM
09/12/15 03:30 PM
RapidRobert
FYI one guy mentioned using a straight piece of alum tubing (3/8 iirc) layed in the pulley grooves to check his alignment and another guy used a laser pointer same way
