Re: old schhol questions
[Re: Mr.Yuck]
#1909336
09/09/15 04:32 PM
09/09/15 04:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My 38 Plymouth required a rod of predetermined length to set the timing, you couldn't use a timing light. Dunno if that's still relevant to the here.
Basically, to set the timing on my 38 you had to pull a pipe plug atop the head on a cylinder, I think it was #1, and rotate the engine till the marks on the rod lined up with the top of the hole, then using a test light rotate the distributor till the points just opened. Some where I still have the FSM for that 38, dunno where though. My suggestion, if this method is still relevant for your 51, is to mark the pulley and fab up a pointer so you only have to do this once.
[Re: Mr.Yuck]
#1909362
09/09/15 05:13 PM
09/09/15 05:13 PM
Supercuda
About to go away
About to go away
up yours
BTW, love your truck. Had one similar for sale near me, he wanted $7500 though. I passed. One day I'll get one.
[Re: Supercuda]
#1909410
09/09/15 06:23 PM
09/09/15 06:23 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
BTW, love your truck. Had one similar for sale near me, he wanted $7500 though. I passed. One day I'll get one. got this one for $2500. Needs work thou.
[Re: Mr.Yuck]
#1909419
09/09/15 06:37 PM
09/09/15 06:37 PM
Supercuda
About to go away
About to go away
up yours
Yeah, $5k buys a lot of parts for them though. www.oldmoparts.com has the original headlight stuff if you need it.
[Re: Supercuda]
#1909548
09/09/15 10:45 PM
09/09/15 10:45 PM
Mr.Yuck
Brookeville, Md
Yeah, $5k buys a lot of parts for them though. www.oldmoparts.com has the original headlight stuff if you need it. oh yeah no kidding... this thing is straight and rust free. The int is SHOT and it needs a re-wire. Tried to fire it but the starter will not engage. Motor turns easy so I'm guessing the starter is toast. It came with 3 extra head light assemblies.
[Re: Mr.Yuck]
#1910796
09/11/15 10:57 PM
09/11/15 10:57 PM
Supercuda
About to go away
About to go away
up yours
I know the old Chevy 6 had that kind of setup, not sure if the Mopar flathead did.
[Re: Mr.Yuck]
#1911934
09/13/15 11:07 PM
09/13/15 11:07 PM
moparpollack
Lil Herman
Lil Herman
85086
no place to see the flywheel. I took the starter off the housing is broken. It will not allow the plunger to go deep enough, hence it will not engage. I found the piece on ebay, i hope it solves the problem. re-manned starters for these (if you can find them) are like $400. Time to find a $375 318 engine and transmission.
[Re: Mr.Yuck]
#1912341
09/14/15 05:51 PM
09/14/15 05:51 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Cool link rick, and pollack, this will be a boosted V8 at some point. I'd like to do a Gen III Hemi, however I just got word on a fresh well done 354 Hemi w/ Turbo 350 trans I can have for 4k.... I want to do a "gasser" type truck. Those old Hemi's love boost. You're very welcome....If given the chance and if it fits the budget I would choose the blown old hemi route before any other option....no brainer The new hemi's are boring IMHO Rickster
