70RR Quater pop out window assembley? #1908311
09/07/15 10:14 PM
09/07/15 10:14 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
When I got my RR the pop out windows were already out. I have replaced the "flex seals".. but have no idea how they go back in there. The SM diagram is worthless.. anyone..??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70RR Quater pop out window assembley? [Re: JMCFAN] #1909492
09/09/15 08:59 PM
09/09/15 08:59 PM
St. Louis
I
Imrare Offline
Imrare  Offline
I
St. Louis
I removed the windows on my 1969 RR (probably the same), replaced the rubber and reinstalled them but that was about 6 years ago...I believe I wrote the sequence down on how to reassemble if you would be interested? I may be able to scan it and email it to you if we could correspond directly. Like I said it was a long time ago but I did replace the seal on both windows.
