best intake ??? #190830
01/11/09 08:01 PM
01/11/09 08:01 PM
wv usa
J WORKMAN Offline OP
wv usa
What would be the best stock intake for a small block ? I need one for a circle track car and have to run the 4412 500 holley. I can run a 4 barrel with a 1 inch adaptor plate. I was thinking a 340 intake. THANKS
Re: best intake ??? [Re: J WORKMAN] #190831
01/12/09 12:13 AM
01/12/09 12:13 AM
CA
David Lee Offline
David Lee  Offline
CA
I assume you are running hobby stock or street stock, what rpm range are you going to be running in?
Ah...so many pedestrians, so little time...
Re: best intake ??? [Re: David Lee] #190832
01/12/09 12:22 AM
01/12/09 12:22 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bet a spreadbore 340/360 thermoquad intake would flow decent for what it is, although what would happen to that flow if you have to put on a spreadbore to squarebore adapter plate is the question...
Re: best intake ??? [Re: DaytonaTurbo] #190833
01/12/09 02:20 AM
01/12/09 02:20 AM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Anything '72 and prior are the best b/c they are non egr
Re: best intake ??? [Re: SuperStocker] #190834
01/12/09 04:31 PM
01/12/09 04:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Also the newer 318-360 4bbl manifolds have smaller runners that more closely match a 318 head than a 360 head.
Since you are restricted to a small carb I would try to find a manifold with the biggest plenum and make it bigger if I could, this will leave you with a spread bore manifold from 71 or 72, biggest plenum and runners and no EGR.
Also if you do end up with a 1 inch spacer than probably going with an open type would make more power but only testing will prove me right or wrong.
Re: best intake ??? [Re: HotRodDave] #190835
01/13/09 04:18 AM
01/13/09 04:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have used the later 360 thermoquad egr intake (off a '76-'77 Cordoba) on a 318 with good results. I just plugged the EGR holes inside the manifold, and added a 4150 carb adaptor for a Holley 600. I think the intake cost me $10, the carb adaptor was $15.
Re: best intake ??? [Re: 451Mopar] #190836
01/13/09 10:16 PM
01/13/09 10:16 PM
wv usa
wv usa
Im sorry but I dont know where the 318 idea came from. I am running a 360 magnum, I should of said that. Sorry
