Where should my Volt meter read if everything is good? #190824
01/11/09 07:48 PM
01/11/09 07:48 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
On the Aftermarket Voltmeter I just installed,While driving it read right on 14 Volts. What are the absolute limits I should look for to determine Overcharge and Undercharge?
Re: Where should my Volt meter read if everything is good? [Re: SPWC] #190825
01/11/09 07:50 PM
01/11/09 07:50 PM
Kirkland, Washington
Pacnorthcuda Offline
absolute? 13-15volts. While running. Normal will be 13.5-14.75 depending on your particular system (Voltage regulator has a lot to do with the high limit)
Re: Where should my Volt meter read if everything is good? [Re: Pacnorthcuda] #190826
01/11/09 07:52 PM
01/11/09 07:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why start another post. You already have one running on these guages.
