4.7 liter Durango. help #1907392
09/06/15 01:00 PM
09/06/15 01:00 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
My Durango has about 100,000 miles and it started burning a quart of oil every 300 miles seems to run perfectly fine no check engine light it just passed smog check a week ago. Although from time to time . A small amount of smoke is visible, any burning odor it doesn't actually smell like burning oil but I'm assuming with it using that much oil it has to be oil burning
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 4.7 liter Durango [Re: WHITEDART] #1907393
09/06/15 01:01 PM
09/06/15 01:01 PM
bean town ....Ca
W
W
bean town ....Ca
Is this a problem with a 4.7 has anybody encounter this and corrected the issue Thanks
Re: 4.7 liter Durango [Re: WHITEDART] #1907596
09/06/15 07:53 PM
09/06/15 07:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A quart every 300 is a lot, try replacing the PCV, I seen one doing that, I have seen more that just smoke till you replace the engine (rings, valve guides)but good luck finding one, I am looking for 3 currently.
Re: 4.7 liter Durango [Re: WHITEDART] #1907855
09/07/15 03:26 AM
09/07/15 03:26 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Maybe it's sucking it up by the intake gasket? Intake is plastic I think.
Re: 4.7 liter Durango [Re: ademon] #1907856
09/07/15 03:31 AM
09/07/15 03:31 AM
GEORGIA
barracuda7199 Offline
GEORGIA
The only way the intake sees oil on a 4.7 is the pcv valve. It is plastic but has a dry valley and o rings to seal the ports. It is an overhead cam engine.
Re: 4.7 liter Durango [Re: WHITEDART] #1908028
09/07/15 02:13 PM
09/07/15 02:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I had an '06 Dakota with the H.O. 4.7. It used a quart every 5-800, and sometimes smoked like crazy on startup. Never did find out why. Traded it off with 60K on it.
Re: 4.7 liter Durango [Re: WHITEDART] #1908029
09/07/15 02:14 PM
09/07/15 02:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm. wife's 05 Ram never had an issue with the 4.7.
Don't be the exception.
Re: 4.7 liter Durango [Re: WHITEDART] #1908177
09/07/15 06:41 PM
09/07/15 06:41 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
4.7s seem to be a crapshoot. They are either troublefree or turds.
Re: 4.7 liter Durango [Re: slantzilla] #1908185
09/07/15 07:00 PM
09/07/15 07:00 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'll agree with checking or replacing the pcv, preferably with a dealer piece.
Re: 4.7 liter Durango [Re: buildanother] #1908381
09/07/15 11:55 PM
09/07/15 11:55 PM
bean town ....Ca
W
W
bean town ....Ca
Okay I change the PCV valve topped off the oil and will inform you as soon as I get enough miles to tell if it helped Thanks
