Re: A-body hood hinge/spring questions
[Re: 440mopar]
#1908463
09/08/15 02:32 AM
09/08/15 02:32 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
As mentioned, the car was painted with the fenders on, so the bottoms of the hinges and the inboard sides got partial paint.
These 69 Barracuda hinges are in the original paints, the gray dip primer on the lower part, the hand brushed zinc rich primer applied at the factory to bolted joint interfaces since they would not get top coated, and the medium metallic green top coat.
The top photo shows the inboard side with partial top coat. The bottom photo shows the gray primer dip line left of the rivet.
[Re: kentj340]
#1908464
09/08/15 02:45 AM
09/08/15 02:45 AM
kentj340
Cut and Shoot, TX
These photos were taken before the hinges were de-rusted with Safest Rust Remover. I prefer to chemically treat rather than sand blast if at all possible.
The top photo shows the dark green zinc rich primer hand brushed on the bolted joint. The bottom photo shows the outboard side did get mostly top coated. All 4 photos are the same L hinge.
The rust remover cleaned all the rust off nicely and also took off loose paint especially on the spring.
[Re: kentj340]
#1908758
09/08/15 05:56 PM
09/08/15 05:56 PM
Posts: 732 USA
440mopar
USA
