rad hoses #1907687
09/06/15 10:34 PM
09/06/15 10:34 PM
ky, usa
littlejohn44 Offline OP
ky, usa
i have a weird radiator combo going on and in need of hoses. Where do yall get yours from and is there anything to look out for? i need to be able to flex it almost 90* without caving it in.
Re: rad hoses [Re: littlejohn44] #1907725
09/06/15 11:03 PM
09/06/15 11:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Top or bottom hose.. SB or BB.... have you looked into
a 90* thermostat housing that will swing to what you need
wave
Re: rad hoses [Re: littlejohn44] #1907730
09/06/15 11:08 PM
09/06/15 11:08 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Sometimes something like this is your best bet http://www.jegs.com/p/JEGS-Performance-P...ge=90&pno=1
"Just a Bracket car dressed up like a streetcar"
Re: rad hoses [Re: Just-a-dart] #1907882
09/07/15 09:31 AM
09/07/15 09:31 AM
moparx Offline
moparx  Offline
i go to the "help" section at your local parts emporium, and get one of those expandable/flexible, "heat stove" tube things that go between the air cleaner intake tube and exhaust manifold, these were used on almost every mid70-80's vehicles, and come in several sizes, including 1 1/2" and 1 3/4" which is your standard upper and lower radiator hose sizes. i then just form it to the shape i like for the hose routing needed, then hit the parts store hose selection until i find one that will work for my combination. sometimes, it is necessary to employ straight sections of hose and bend tubing to get the results i am after, but the flexy exhaust tube stuff works great, holds it's shape until you are done, and then you just collapse it back to the straight, as packaged shape and use it again on your next project. hope this may be of some help.
beer
Re: rad hoses [Re: littlejohn44] #1907979
09/07/15 01:10 PM
09/07/15 01:10 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I'd take some measurements and go down to your local parts store and ask to look at the hoses they have in stock to see if something will work. I've done this a couple of times. Once you find one you always have the part number to get a replacement should you ever need one....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: rad hoses [Re: littlejohn44] #1908241
09/07/15 08:31 PM
09/07/15 08:31 PM
ky, usa
ky, usa
I didnt think of the flexi duct. I couldnt wrap my mind around a way to bring the shape i needed to the parts store.On my bottom the way it comes out my oil filter is halfway in the way so i have to go around to come up to the wp. on the top its almost a straight shot if i need it to be.
