Re: Do air nibblers work well?
[Re: DaytonaTurbo]
#190740
01/11/09 11:17 PM
01/11/09 11:17 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I used a nibbler to cut the roof skin off my Dart. It was fast and did a smooth job. But, it throws those little crescent shaped scraps everywhere. Mine does curves but I need to keep the tool oriented properly or it won't cut.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: DaytonaTurbo]
#190743
01/13/09 06:38 PM
01/13/09 06:38 PM
Posts: 6,516 Santa Cruz, California
Lefty
To cut sheet metal I've been using either an angle grinder and mostly my die grinder with a cut off wheel. It works but is there something better for cutting curves? I've seen tools for cutting sheet metal called air nibblers but never used one or even seen one outside of a store. Do they work well? Or is there something else I should look at?
Yes I would love a plasma cutter, but that's just not gonna happen. $$$
Body saws work good for cutting curves in sheet metal and the replacement blades are cheap. If you plan to use it often I would pass on the $20 dirt cheap ones on eBay and get a "name" brand.
http://www.google.com/search?hl=en&q=body+saw&btnG=Google+Search
[Re: Lefty]
#190744
01/13/09 06:45 PM
01/13/09 06:45 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
and don't buy Blue Point junk from Snap-On either, more noise than cutting
