Do air nibblers work well? #190733
01/11/09 07:15 PM
01/11/09 07:15 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
To cut sheet metal I've been using either an angle grinder and mostly my die grinder with a cut off wheel. It works but is there something better for cutting curves? I've seen tools for cutting sheet metal called air nibblers but never used one or even seen one outside of a store. Do they work well? Or is there something else I should look at?
Yes I would love a plasma cutter, but that's just not gonna happen. $$$
Re: Do air nibblers work well? [Re: DaytonaTurbo] #190734
01/11/09 07:18 PM
01/11/09 07:18 PM
Kirkland, Washington
Pacnorthcuda Offline
I bought a cheap Harbor freight one for $30. Works great. Bites off little 'crescent moon' bits. Does NOT warp either side of the panel, its fast, no heat. They are the way.
Re: Do air nibblers work well? [Re: Pacnorthcuda] #190735
01/11/09 07:20 PM
01/11/09 07:20 PM
Manitoba, Canada
Manitoba, Canada
How smooth does it cut? Do you have to cut a little big so you can go back over it after and smoot out your curve?
Re: Do air nibblers work well? [Re: DaytonaTurbo] #190736
01/11/09 07:23 PM
01/11/09 07:23 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I have one and it works great except it really wears out the punch and die in a hurry. No need to smooth out after using them they do a very clean job.
Sheldon
Re: Do air nibblers work well? [Re: DaytonaTurbo] #190737
01/11/09 07:24 PM
01/11/09 07:24 PM
It cuts VERY smooth as in no burring, but you will get a little sawtooth pattern from the bites. If its a finished edge your looking for then yes, you would need to dress it with a file.
And the slower you go the smaller the bites and the smoother the line
Re: Do air nibblers work well? [Re: Pacnorthcuda] #190738
01/11/09 08:02 PM
01/11/09 08:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a Blue Point one that I've had for years. Never worn out a punch yet. An air shear will make a smoother edge.
Re: Do air nibblers work well? [Re: slantzilla] #190739
01/11/09 11:07 PM
01/11/09 11:07 PM
Manitoba, Canada
Manitoba, Canada
Thanks for the info. I've been thinking about an air shear for a while as well. Will probably end up buying both.
Re: Do air nibblers work well? [Re: DaytonaTurbo] #190740
01/11/09 11:17 PM
01/11/09 11:17 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
I used a nibbler to cut the roof skin off my Dart. It was fast and did a smooth job. But, it throws those little crescent shaped scraps everywhere.
Mine does curves but I need to keep the tool oriented properly or it won't cut.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Do air nibblers work well? [Re: DaytonaTurbo] #190741
01/11/09 11:20 PM
01/11/09 11:20 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
I have an HF one, it works well, but I do not use it much as the little 1/2 moon things get everwhere..
stick to your feet and get tracked in the house and step on them when you are bare foot. They have their place, but I use the electric shear when I can (it will not cut as sharp of a curve, but it is nice). I use the hell out of the cut off wheel, most of the time I cut something I use the 4.5" cut off wheel on a small angle grinder.
Re: Do air nibblers work well? [Re: 6T6Cuda] #190742
01/13/09 02:16 AM
01/13/09 02:16 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I have one for about 10 years, I try to use it over the scrap/ garbage can when trimming to keep the slugs from being everywhere, they are a Pain.
I havent worn out a bit yet, it works great.
Re: Do air nibblers work well? [Re: DaytonaTurbo] #190743
01/13/09 06:38 PM
01/13/09 06:38 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Body saws work good for cutting curves in sheet metal and the replacement blades are cheap. If you plan to use it often I would pass on the $20 dirt cheap ones on eBay and get a "name" brand.
http://www.google.com/search?hl=en&q=body+saw&btnG=Google+Search
Re: Do air nibblers work well? [Re: Lefty] #190744
01/13/09 06:45 PM
01/13/09 06:45 PM
Jacksonville Florida
elitecustombody Offline
and don't buy Blue Point junk from Snap-On either, more noise than cutting
Re: Do air nibblers work well? [Re: elitecustombody] #190745
01/13/09 07:30 PM
01/13/09 07:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Princess Auto baby !!!!!!!!
The nibbler works well as long as the gauge is not too heavy, you have constant and sufficient air pressure, you hold the tool firmly against the surface and you feed at the proper speed. It will cut any shape but only as good as your aim. If you've got the shakes then don't expect a nice straight line!
Shears work better on long straight cuts and sweeping curves. If I have a choice of which to use I usually pick up the shear (a lot less mess too!)
