4.7 liter Durango. help
#1907392
09/06/15 01:00 PM
09/06/15 01:00 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
My Durango has about 100,000 miles and it started burning a quart of oil every 300 miles seems to run perfectly fine no check engine light it just passed smog check a week ago. Although from time to time . A small amount of smoke is visible, any burning odor it doesn't actually smell like burning oil but I'm assuming with it using that much oil it has to be oil burning
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: 4.7 liter Durango
[Re: WHITEDART]
#1907393
09/06/15 01:01 PM
09/06/15 01:01 PM
WHITEDART
bean town ....Ca
Is this a problem with a 4.7 has anybody encounter this and corrected the issue Thanks
[Re: WHITEDART]
#1907596
09/06/15 07:53 PM
09/06/15 07:53 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
A quart every 300 is a lot, try replacing the PCV, I seen one doing that, I have seen more that just smoke till you replace the engine (rings, valve guides)but good luck finding one, I am looking for 3 currently.
[Re: ademon]
#1907856
09/07/15 03:31 AM
09/07/15 03:31 AM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
Maybe it's sucking it up by the intake gasket? Intake is plastic I think. The only way the intake sees oil on a 4.7 is the pcv valve. It is plastic but has a dry valley and o rings to seal the ports. It is an overhead cam engine.
[Re: WHITEDART]
#1908028
09/07/15 02:13 PM
09/07/15 02:13 PM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
I had an '06 Dakota with the H.O. 4.7. It used a quart every 5-800, and sometimes smoked like crazy on startup. Never did find out why. Traded it off with 60K on it.
[Re: WHITEDART]
#1908029
09/07/15 02:14 PM
09/07/15 02:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm. wife's 05 Ram never had an issue with the 4.7.
[Re: WHITEDART]
#1908177
09/07/15 06:41 PM
09/07/15 06:41 PM
slantzilla
Park Forest, IL
4.7s seem to be a crapshoot. They are either troublefree or turds.
[Re: buildanother]
#1908381
09/07/15 11:55 PM
09/07/15 11:55 PM
WHITEDART
bean town ....Ca
Okay I change the PCV valve topped off the oil and will inform you as soon as I get enough miles to tell if it helped Thanks
