Thanks to all! Got the locking lug nuts off! #190703
01/11/09 06:47 PM
01/11/09 06:47 PM
chattanooga tn
sm73charger Offline OP
chattanooga tn
Re: need to remove locking lug nuts,dont have a key [Re: sm73charger] #190704
01/11/09 06:50 PM
01/11/09 06:50 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
A lot of tire shops have a socket that will go over and grip the nut to turn it off. I've seen them split after hitting them with a chisel or you could weld a nut on them.
Sheldon
Re: need to remove locking lug nuts,dont have a key [Re: RUNCHARGER] #190705
01/11/09 07:02 PM
01/11/09 07:02 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Use a piece of black pipe and pound it onto the offending lug then twist it with a pipe wrench. Chop the end with the lug in it off, rinse, repeat.
I can't afford this. mark
Re: need to remove locking lug nuts,dont have a key [Re: a12superbee] #190706
01/11/09 07:19 PM
01/11/09 07:19 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Sears has a set of impact sockets for exactly this problem.
Re: need to remove locking lug nuts,dont have a key [Re: bobby66] #190707
01/11/09 07:21 PM
01/11/09 07:21 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
If Sears sells these tools for would-be thieves....why do we continue to put them on our vehicles?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: need to remove locking lug nuts,dont have a key [Re: sm73charger] #190708
01/11/09 08:04 PM
01/11/09 08:04 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
The van i bought last year in CA had wheel locks no key. Since the wheels were alloy slots there were no spoles around the nuts to get in the way. I took a chisel and made a notch on the outsde edge of the nut when it was large enough I beat it counter clockwise and after a few hits they spun right off.
Don't miss or you will mess up alloy wheels!
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: need to remove locking lug nuts,dont have a key [Re: Pyper70] #190709
01/11/09 08:04 PM
01/11/09 08:04 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Because knuckleheads like me cant keep track of the keys to the locks.
Re: need to remove locking lug nuts,dont have a key [Re: sm73charger] #190710
01/11/09 08:48 PM
01/11/09 08:48 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have done it a ton of times...just get a socket a little too small to fit over the lug nut (a 12 point) and pound it on with a big (use an extension to make it easier to hit) then just hit it with the impact gun and you're set. Once it's off..I just set the socket in the vise and tap out the lug with a drift.
I always use Craftsman so if I ever happen to split a socket, it's only a quick trick to Sears for a new one
Re: need to remove locking lug nuts,dont have a key [Re: OzHemi] #190711
01/11/09 09:36 PM
01/11/09 09:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take a punch and drive the center pin of the lock into the nut and then just use a ratchet and extension as a key. I've done it dozens of times on used cars. The stud doesn't go all the way into the nut so there is room for the pin to go in.
Re: need to remove locking lug nuts,dont have a key [Re: stumpy] #190712
01/11/09 10:04 PM
01/11/09 10:04 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
I've used an oil sender socket. Works like a charm.
Re: need to remove locking lug nuts,dont have a key [Re: farmington] #190713
01/11/09 10:17 PM
01/11/09 10:17 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
If they are that easy to defeat, I'm gonna get rid of mine and just run regular lugs. They are a PITA anyway. And probably do nothing for my wheel balance.
Re: need to remove locking lug nuts,dont have a key [Re: pyp1000] #190714
01/12/09 12:44 AM
01/12/09 12:44 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Tighten the other 4 up more. Then get a flat blade square shank screw driver and jam it into the slot for the key. Find the pattern it fits best in. Then put a wrench on the shank and turn...usually does it for me.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: need to remove locking lug nuts,dont have a key [Re: 69superbee383] #190715
01/12/09 01:18 AM
01/12/09 01:18 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Don't overthink it, locking lugnuts are a joke...Listen t OzHemi and pound a socket on 'em and spin 'em off. Use a Craftsman socket so when it splits you can exchange it for a new one...
Re: need to remove locking lug nuts,dont have a key [Re: RUNCHARGER] #190716
01/12/09 01:24 AM
01/12/09 01:24 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Sheldon
Bought new tires for my truck, made a right out of the tire shop in time to see my Mag KEY go sliding off my hood into the black hole of center median foliage!!!!! Gone forever. Turned around, in less then 5 minute the shop had all 4 off and repace with new locks (at their expense)
go to a local tire shop and ask them to knock them off maybe buy a 12pk of beverages
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: need to remove locking lug nuts,dont have a key [Re: farmington] #190717
01/12/09 08:40 PM
01/12/09 08:40 PM
chattanooga tn
chattanooga tn
sorry, but what is an oil sender socket? thanks
Re: need to remove locking lug nuts,dont have a key [Re: farmington] #190718
01/12/09 08:41 PM
01/12/09 08:41 PM
chattanooga tn
chattanooga tn
Re: need to remove locking lug nuts,dont have a key [Re: sm73charger] #190719
01/12/09 08:46 PM
01/12/09 08:46 PM
Kirkland, Washington
Pacnorthcuda Offline
Its an oddball socket shaped like an oil sending unit. You DONT need it for this. Find a socket that almost fits on the lugnut. HAMMER it on. Remove with impact if you have one, regular ratchet/breaker if you dont
Re: need to remove locking lug nuts,dont have a key [Re: Pacnorthcuda] #190720
01/12/09 08:52 PM
01/12/09 08:52 PM
chattanooga tn
chattanooga tn
will this still work if the locking lug nut is one of those round ones? (meaning it is not hex shaped but rather smooth. thanks again
Re: need to remove locking lug nuts,dont have a key [Re: sm73charger] #190721
01/12/09 08:53 PM
01/12/09 08:53 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Yes...pound a socket on as I mentioned...I have done it on all sorts and kinds of lock nuts.
Re: need to remove locking lug nuts,dont have a key [Re: OzHemi] #190722
01/12/09 09:12 PM
01/12/09 09:12 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
This has been an issue since 5 minutes after the first set was sold.
As mentioned, the big tool guys have special tools for this, or you can use the various options mentioned.
The easiest for you is to go to a good tire shop and have them do it. The 50th set you do is easier than the first. Those guys have already done 50....
