Re: need to remove locking lug nuts,dont have a key
[Re: RUNCHARGER]
#190705
01/11/09 07:02 PM
01/11/09 07:02 PM
Posts: 6,301 colorado
a12superbee
colorado
Use a piece of black pipe and pound it onto the offending lug then twist it with a pipe wrench. Chop the end with the lug in it off, rinse, repeat.
I can't afford this.
mark
[Re: sm73charger]
#190708
01/11/09 08:04 PM
01/11/09 08:04 PM
Posts: 3,934 Nova Scotia Canada B2Y 1E4
SANDYinNS Canada
The van i bought last year in CA had wheel locks no key. Since the wheels were alloy slots there were no spoles around the nuts to get in the way. I took a chisel and made a notch on the outsde edge of the nut when it was large enough I beat it counter clockwise and after a few hits they spun right off. Don't miss or you will mess up alloy wheels!
Sandy in Nova Scotia formerly drdodge340 68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute -76 feather duster-76 duster-77 street van - 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
[Re: Pyper70]
#190709
01/11/09 08:04 PM
01/11/09 08:04 PM
Posts: 3,805 Arlington, Texas
bobby66
Arlington, Texas
Sears has a set of impact sockets for exactly this problem.
If Sears sells these tools for would-be thieves....why do we continue to put them on our vehicles?
Because knuckleheads like me cant keep track of the keys to the locks.
[Re: pyp1000]
#190714
01/12/09 12:44 AM
01/12/09 12:44 AM
Posts: 6,679 Va. Beach, Va
69superbee383
Va. Beach, Va
Tighten the other 4 up more. Then get a flat blade square shank screw driver and jam it into the slot for the key. Find the pattern it fits best in. Then put a wrench on the shank and turn...usually does it for me.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: RUNCHARGER]
#190716
01/12/09 01:24 AM
01/12/09 01:24 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
A lot of tire shops have a socket that will go over and grip the nut to turn it off. I've seen them split after hitting them with a chisel or you could weld a nut on them.
Sheldon
Bought new tires for my truck, made a right out of the tire shop in time to see my Mag KEY go sliding off my hood into the black hole of center median foliage!!!!! Gone forever. Turned around, in less then 5 minute the shop had all 4 off and repace with new locks (at their expense)
go to a local tire shop and ask them to knock them off maybe buy a 12pk of beverages
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: sm73charger]
#190719
01/12/09 08:46 PM
01/12/09 08:46 PM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
what is an oil sender socket?
Its an oddball socket shaped like an oil sending unit. You DONT need it for this. Find a socket that almost fits on the lugnut. HAMMER it on. Remove with impact if you have one, regular ratchet/breaker if you dont
