Page 19 of 21 1 2 17 18 19 20 21
Re: Gen III Hemi, please post things to avoid and know.. [Re: ntstlgl1970] #1906715
09/05/15 03:35 AM
09/05/15 03:35 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Originally Posted By ntstlgl1970
Darius has been struggling to get his car driving right, he is in the same car club as me. To my knowledge he is not running the NAG1 as a stand alone....
The NAG1 is the same as the mercedes transmission that they use in a bunch of different chassis with a different id - I think it's called a 722.6 or something like that.
Quick followup on the NAG1- I talked to Darius at Sac raceway last weekend and he finally got his trans sorted out, its not a stand alone controller though. Biggest problem is just chrysler not wanting to support these types of swaps by sharing data like GM and Ford do.
Re: Gen III Hemi, please post things to avoid and know.. [Re: ntstlgl1970] #1920423
09/27/15 02:37 AM
09/27/15 02:37 AM
Arizona
Chris'sBarracuda Offline
Arizona
Cool video explaining the differences between the Apache and Hellcat heads.. thumbs
https://www.facebook.com/moparmusclemag/videos/10153679527602792/?fref=nf
Chris.. wave
Re: Gen III Hemi, please post things to avoid and know.. [Re: Chris'sBarracuda] #1920432
09/27/15 02:48 AM
09/27/15 02:48 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I had not seen that, thanks Chris
"Just a Bracket car dressed up like a streetcar"
Re: Gen III Hemi, please post things to avoid and know.. [Re: Street Monkies] #1921011
09/28/15 02:24 AM
09/28/15 02:24 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Originally Posted By Street Monkies
Roughly what is the cost to build one of these engines for drag race use? From low to high cost.
Depends on your HP target.
Buggest inhibitor is the crappy slugs, piston/valve clearance and rods - so with an unopened motor I dont think youd see much more than appx 520 fwhp NA with a 6.1' ported heads, cam, headers, tune and modded intake.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen III Hemi, please post things to avoid and know.. [Re: Just-a-dart] #1921039
09/28/15 05:53 AM
09/28/15 05:53 AM
Arizona
Arizona
Welcome Don..
I just noticed that I didn't title it..
DONE.. up
Chris.. wave
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1933717
10/17/15 11:39 AM
10/17/15 11:39 AM
USA
hudsonhornet7x Offline
USA
Question:
Does anyone know the chamber size for eagle heads as well as 6.1 heads?
Would one head offer an advantage over the other?
Thanks for any input.
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1933826
10/17/15 04:05 PM
10/17/15 04:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Eagle 65cc
6.1 73cc
Whichever ones you have use, or get Apaches.
Mopar to the bone!!!
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1934643
10/19/15 02:13 AM
10/19/15 02:13 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Looking for the part numbers for the 6.4 hemi factory replacement crate engine, 470 hp non-MDS, and the 6.1 hemi factory replacement crate engine. Any help with this would be greatly appreciated! Thank you!
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1939169
10/26/15 08:57 PM
10/26/15 08:57 PM
Renton Washington
Triple Threat Offline
Renton Washington
If using a 6.4 apache head on an early 5.7 block what head gasket is needed? 5.7 bore is likely too small, will the 6.4 work? 6.1?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1940174
10/28/15 06:57 AM
10/28/15 06:57 AM
gregsdart Offline OP
I was told to use the gasket that matches the block. As far as bore goes, there must be an after market gasket that will work. Guys have bored the 5.7 to 4.00. According to a picture of Apache heads sitting on a 5.7 un bored block, the chambers on the Apache heads are small enough to work with a 4.00 bore gasket.
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1940362
10/28/15 02:33 PM
10/28/15 02:33 PM
Renton Washington
Renton Washington
Cometic 5.7L gaskets are 4.100 bore, so should be good there.
-Dustin
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1941150
10/29/15 06:08 PM
10/29/15 06:08 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
What head is on a 06 6.1 SRT8 engine?
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1941152
10/29/15 06:15 PM
10/29/15 06:15 PM
Renton Washington
Renton Washington
All 6.1's use the same head, its just known as the 6.1, no code name.
-Dustin
Re: Gen III Hemi, please post things to avoid and know.. [Re: cudaman1969] #1941156
10/29/15 06:18 PM
10/29/15 06:18 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
They're just called 6.1 heads, no fancy name for them, still a good head, flow #'s comparable to an Eagle head
Re: Gen III Hemi, please post things to avoid and know.. [Re: WO23Coronet] #1941161
10/29/15 06:28 PM
10/29/15 06:28 PM
fredericksburg,va
fredericksburg,va
Do they have problems with seats popping out?
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1941207
10/29/15 07:43 PM
10/29/15 07:43 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I don't think so, it's the early 5.7 heads that we're known to do that, and generally (but not always) only if they were heated/ran hot
Re: Gen III Hemi, please post things to avoid and know.. [Re: WO23Coronet] #1941425
10/30/15 12:31 AM
10/30/15 12:31 AM
fredericksburg,va
fredericksburg,va
Think it was over reved and broke top of lifter. Looked in pushrod hole with bore scope, saw seat beat up
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2033959
03/18/16 06:25 PM
03/18/16 06:25 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
5.7 stroker about to hit the track soon.
https://www.youtube.com/watch?v=X6LmseKXLzI
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2034164
03/18/16 11:39 PM
03/18/16 11:39 PM
USA
USA
Any specs on that? Is sounds great!
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2034203
03/19/16 12:18 AM
03/19/16 12:18 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
It is a BFNY build, IIRC Eagle heads, 12.1 and a decent cam.
