Re: Wheel balancing, will this work?
[Re: kenz]
#1906730
09/05/15 05:29 AM
09/05/15 05:29 AM
RapidRobert
Could I mount a 1" hub centric spacer that has integral studs to the wheels and use that as the centering device? Any thoughts? I would think that the hub centric spacer would center the spacer on the hub/drum cuz the center hole of it would fit tight on the raised register and the lug centric spacer with the right lug nuts of course would center the wheel on the spacer. there oughta be an easier way than fabbing one of those up tho. Can you use some 1" (wrench needed) racing 1/2" tapered lug nuts to center the wheels as is?
[Re: autoxcuda]
#1906739
09/05/15 08:28 AM
09/05/15 08:28 AM
Challenger 1
Cincinnati, Ohio
What's a SS lookalike? You mean a Magnum 500?
We have an old school alignment shop in town and they would do old school On Car wheel balancing with my brothers magnum 500's on his 70 Mach 1.
You spin the wheel with a machine with a drum to drive the tire. Then the guy feels the fender for vibration. Adds weight through a trial and error and experience process. Works very well. I think you are referring to a strobe balancer, uses a strobe light to help you balance the wheel tire assemy. I have one. Does the OP have picture of the rim in question, I bet anyone could balance it? Why would WV make a wheel that is hard to get balanced? FWIW, this is the strobe part of the balancer. The vibration sensor mounts under the car on the corner your balancing and the strobe faces the tire. You usually put a white mark on the tire sidewall right next to the valve stem or use the valve stem as reference and spin the tire assy and use the strobe to determine where the weights go, no guessing involved. Can't find a picture of the motor that drives the wheel yet, but did find this picture of my tire lathe. It'll true the tire on the spindle to provide a exactly round tire. It minimizes big time how much weight must be used to balance your tire and provides a super smooth ride. Makes your tires last longer too.
[Re: Challenger 1]
#1906807
09/05/15 11:40 AM
09/05/15 11:40 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I bet anyone could balance it? Why would WV make a wheel that is hard to get balanced? Not just WV. From Specialty Wheels website; "WHEEL BALANCING All of our wheels are designed to be balanced from the lug holes only" Over the past few years, between myself and friends, we have purchased 5 sets of Magnum style wheels. 3 from WV and 2 from Specialty. There is no one in our area that can balance by lug holes so we balanced the normal way. All balanced up well, normal amount of weights and no vibration at highway speed. Lug hole balancing is probably the better way, but we have had no problems with the normal way.
[Re: kenz]
#1906823
09/05/15 12:02 PM
09/05/15 12:02 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I cant believe no one in your town has a lug centric adapter for their machines, they have been common for at least 20 plus years that I know of. It is a fixture with pins that go through the lug holes and then the cup goes over them to hold the whel tight. Many have adjustable pins and some are pattern specific. Next time I'm in one of my stores and think about it I'll gtet a picture and post it. Their are usually several sizes in the basic accessory kit when you buy a balancer of any quality. A high percentage of dually tires are lug centric. Someone in your town has to have them, they are required/essential equipment for many manufactures. Here is an example of one style I pulled off of the bag. http://www.ebay.com/itm/LUG-CENTRIC-ADAP...633&vxp=mtr
Careful, your character's showing!
[Re: kenz]
#1906834
09/05/15 12:21 PM
09/05/15 12:21 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
when I had cars with magnum 500 wheels I made my own adaptor to properly balance them.
I picked up a 70's 2 piece rotor and removed the rotor from the hub, removed the inner bearing races and installed new wheel studs. it slid right on the balancer shaft and I used a small cone to center the hub on the shaft. it worked perfect. the only problem is I gave it to the buyer of the car when I sold it.
perception is 90% of reality
[Re: 2abodymcodes]
#1907278
09/06/15 02:23 AM
09/06/15 02:23 AM
Posts: 559 Scottsdale, AZ
kenz
Scottsdale, AZ
have you thought about using ceramic beads ? No, I haven't. But now that you mention it, I do remember hearing about them. I think I'll check it out. Thanks.
