Re: B-E k frame
[Re: mk_]
#1906673
09/05/15 01:46 AM
09/05/15 01:46 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Not totally sure on this one... but the steering box mount may be on a slightly different angle on the older 66-70 B bodies vs E bodies. Yes. 70 B-body is a one year only K-member. It has the 66-70 B-body steering angle. BUT it has the through K-member sway bar pass through cutouts that 70-72 B-body and 70-74 E-body have. Those two features ONLY happen together on a 70 B-body K-member.
Re: B-E k frame
[Re: thehemikid]
#1906728
09/05/15 05:19 AM
09/05/15 05:19 AM
autoxcuda
So Cal
And then there's the late 69 transition K to muddy thing up a bit. Yep, forgot about that. That happens a little bit in 1972 also on A-bodies as they transition to 73 through sway bar K-members.
