Re: starter question/ verification
[Re: stumpy]
#1906038
09/03/15 11:59 PM
09/03/15 11:59 PM
RapidRobert
highly likely the starter. I would confirm by setting a known charged batt by the dr front tire & jumping to the starter large/small terminals. clamp them together first before making the final connection at the battery to keep sparks from messing up the stud threads & make sure the clamps cannot shift & touch the starter case (a helper to hold them might work) when it starts cranking
[Re: mikemee1331]
#1906105
09/04/15 01:28 AM
09/04/15 01:28 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Put a mini from say a 99 360 truck in it.You will never use the old type again unless its a 100 point resto.Rocky
Chrysler Firepower
[Re: 383man]
#1906481
09/04/15 07:25 PM
09/04/15 07:25 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Do you see the starter drive pull back as it could be the one way clutch drive is going bad. Ron i suspect that is the problem. it will crank for what i'll call 2 engine revolution and then 'free-spin'. i hooked it up to a jump starter just to verify the battery and it does the same thing. i was busy with brake stuff and fighting to get that brake reinforcement plate off, so i didn't get a chance to crawl under and watch the starter. i'm just gonna replace it. i have to pull the header on that side anyway to SEAL my 'Percy's Seal-for-Life' gasket.
[Re: mikemee1331]
#1906486
09/04/15 07:47 PM
09/04/15 07:47 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I see that word Header. Limited space was my problem with Bigger Tube Hooker Headers in the E Body with a Hemi. I would run the short factory stock starters and knew it would have limited life from the closeness to the Headers and heat. I did what Rocky said to do years ago and the clearance problems and heat on the starter problems seemed to disappear. The one Rocky has stated I believe is the type I put in the car. Can not remember if I took off that piece the wiring bolts to but you will see if it needs to be taken off if there is a clearance problem with the wiring.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#1906495
09/04/15 08:00 PM
09/04/15 08:00 PM
mikemee1331
bethlehem pa
I see that word Header. Limited space was my problem with Bigger Tube Hooker Headers in the E Body with a Hemi. I would run the short factory stock starters and knew it would have limited life from the closeness to the Headers and heat. I did what Rocky said to do years ago and the clearance problems and heat on the starter problems seemed to disappear. The one Rocky has stated I believe is the type I put in the car. Can not remember if I took off that piece the wiring bolts to but you will see if it needs to be taken off if there is a clearance problem with the wiring. i agree 100% with the header heat. this will be the 4th one i've replaced in probably 6 years of actually driving it. when i was a kid with a different RR i remember having to replace them regularly too. i'm done with that over weight, enormous stock style and gonna do as Rocky suggested. i will miss that starter crank sound though.......
[Re: mikemee1331]
#1906547
09/04/15 10:01 PM
09/04/15 10:01 PM
hemicar1971
Chicago Blackhawks
It really was the lack of room with the Big Tube Hookers on the Hemi. No room at all and the smaller factory starter just touched the headers and that is not a good thing with the heat. I thought about wrapping the headers in the starter area on the headers and using the old style starter but I ended up wrapping the headers of the Big Tube Hookers with the Rocky style starter and that worked great. I have a little smaller tube Hemi Hooker Headers on the motor now and did not use the wrap but used the same Starter and there is plenty of clearance for the starter and I do not have to pull the header off to get the starter out. I like those new Style little starters, I can put up with the new noise that comes out of them.
