Sidewinder heads #1905935
09/03/15 10:30 PM
09/03/15 10:30 PM
Texas
Shouse1970 Offline OP
Texas
On the big block sidewinder heads, what diameter pushrods can you run without having to grind for clearance. I will be running 1.5 rockers. Thanks
Re: Sidewinder heads [Re: Shouse1970] #1905989
09/03/15 11:24 PM
09/03/15 11:24 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We suggest the 5/16s for no grinding. Smith Brothers and others make them in .080 and .120 that will handle up to 700 psi which is more than wnough for any flat tappet and small rollers.
Todd
Re: Sidewinder heads [Re: Shouse1970] #1906026
09/03/15 11:52 PM
09/03/15 11:52 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
hey Todd,
how are the heads going ?
Crank is back in the block up
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
