cam install inside car? #1904816
09/02/15 12:35 PM
09/02/15 12:35 PM
central new york
pettyblue440 Offline OP
central new york
is it possible to install a cam in a 383 in a 69 bee w/o removing the engine? thanks, jon
Re: cam install inside car? [Re: pettyblue440] #1904823
09/02/15 12:41 PM
09/02/15 12:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes. Might have to remove vertical support along with radiator. You can eyeball the cam bearings too while cam is out. They may look a bit beat but for sure, make sure the oiling holes are clear.
Re: cam install inside car? [Re: pettyblue440] #1904842
09/02/15 12:58 PM
09/02/15 12:58 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I would probably have the grill out too
Re: cam install inside car? [Re: pettyblue440] #1904845
09/02/15 01:01 PM
09/02/15 01:01 PM
Springfield, MO
Steve88 Offline
Steve88  Offline
Springfield, MO
I recently did a cam swap in my 71RR with a 383 with the engine installed and it went pretty well. I am not sure about the differences between a 69 and 71. I just had to remove the radiator to get the clearnace to remove the cam and install the new new one. The only tricky part was getting the balancer bolt properly torqued. I made a bar out of scrap 1" square tubing and 3/16" plate and bolted it to the balancer so that it would contact the shop floor and prevent the crankshaft from roatating will I tightened the balancer bolt.
Re: cam install inside car? [Re: Morty426] #1904847
09/02/15 01:05 PM
09/02/15 01:05 PM
No Super Bee exp (A body only) but I just measured my Summitt cam for you & it is 22 & 3/4" long. grab your tape/pop the hood & go from there
Re: cam install inside car? [Re: pettyblue440] #1904852
09/02/15 01:09 PM
09/02/15 01:09 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yes its not a problem
Re: cam install inside car? [Re: pettyblue440] #1904857
09/02/15 01:13 PM
09/02/15 01:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Did the one in my Bee years ago.Removed rad and that was it.You do have to finess it out and back in but it does go.Rocky
Chrysler Firepower
Re: cam install inside car? [Re: therocks] #1904892
09/02/15 01:55 PM
09/02/15 01:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagreeI did a in car cam change on a 1967 GTX, I had to slide it around the center hood support. I have a freind who use to help a freind race a 1967 GTX and they change cams many times, he also has several 1968 and later B body that he has swapped cams in in the car, there're much easier he says shruggy
Re: cam install inside car? [Re: pettyblue440] #1904951
09/02/15 03:11 PM
09/02/15 03:11 PM
central new york
central new york
thanks guys. the car has 50k and the engine has never been torn into. i plan on putting a timing chain in at some point so may add the cam while i am in there.
Re: cam install inside car? [Re: pettyblue440] #1904973
09/02/15 03:32 PM
09/02/15 03:32 PM
AndyF Offline
AndyF  Offline
This article gives you some tips on cam swapping without pulling the engine:
http://www.moparts.org/Tech/Archive/bb/Lobe.html
Re: cam install inside car? [Re: pettyblue440] #1904989
09/02/15 03:54 PM
09/02/15 03:54 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have a 69 Bee , only need to pull the radiator.
Re: cam install inside car? [Re: pettyblue440] #1905018
09/02/15 04:21 PM
09/02/15 04:21 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Did a cam swap on my '66 Charger in the parking lot at work. Didn't really have a safe place to get it done. Broke it in, changed the oil, and I was on my way.
